340 started...now come the questions #74676
06/16/08 09:09 PM
06/16/08 09:09 PM
Ashburn, Virginia
ashburnmike Offline OP
Ashburn, Virginia
The 340 started last weekend. It sounds good and strong but...
the oil prssure gauge is almost pinned on the high side. is this just a start up thing or could something else be wrong. New Sending unit. New Wiring harness.
The temperature gauge pinned itself on HOT in a very few minutes. New water pump. New Thermostat.
I shut it down and took the thermostat out. The needle pointed a little north toward the warm side when I started it again but seemed fine. Should I just leave it out?
while the car is running my eyes are burning. I was told by a Chevy guy that the AVS is running rich...don't know if I trust a Chevy guy
I don't know anything about this carb and the manual is little help. Any thoughts?
Thanks again
AM
Re: 340 started...now come the questions [Re: ashburnmike] #74677
06/16/08 09:12 PM
06/16/08 09:12 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Are you sure you have the correct sending units ? You may have sending units for idiot lights instead of gauges.
Re: 340 started...now come the questions [Re: AdamR] #74678
06/16/08 09:21 PM
06/16/08 09:21 PM
Ashburn, Virginia
Ashburn, Virginia
they are the correct sending units...at least they were the replacement units Year One Sells for a '70 340 Motor. They look the same as the original units I replaced.
Re: 340 started...now come the questions [Re: ashburnmike] #74679
06/16/08 09:29 PM
06/16/08 09:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The dash voltage limiter a little off? Is it an A body w/rallye dash?
Re: 340 started...now come the questions [Re: buildanother] #74680
06/16/08 09:34 PM
06/16/08 09:34 PM
your AVS is running rich & no you cannot trust a cheby guy & if this was initial breakin you would want the thermostat out for that 20 minute deal. I would guess that the stat was just stuck closed.
Re: 340 started...now come the questions [Re: RapidRobert] #74681
06/17/08 06:55 AM
06/17/08 06:55 AM
Ashburn, Virginia
Ashburn, Virginia
Yes, it is the rally dash. Im not sure what or where the voltage limiter is. On the back of the gauges? What might happen if the oil pressure is too high?
The thermostat was new but I guess it's not unusual for new / rebuilt components to not work.
As far as the carb goes there are several adjustment screws on it but I'm not sure what screw does what.
thanks
AM
Re: 340 started...now come the questions [Re: ashburnmike] #74682
06/17/08 08:36 AM
06/17/08 08:36 AM
chicagoland,usa
chicagoland,usa
If you have an A body rallye dash, the voltage limiter for gauges is built-in to the fuel gauge. Posted here in the past is a fix for that situation. I was fotunate to find an nos fuel gauge a few years ago. The fuel, temp and gas gauges were all reading way high in my case, maybe yours too.
Re: 340 started...now come the questions [Re: buildanother] #74683
06/17/08 07:30 PM
06/17/08 07:30 PM
Ashburn, Virginia
Ashburn, Virginia
Thanks. So, your gauges were all running high until you replaced it...and now it's fine?
I'll hunt for that posting.
AM
Re: 340 started...now come the questions [Re: ashburnmike] #74684
06/17/08 11:28 PM
06/17/08 11:28 PM
chicagoland,usa
chicagoland,usa
Yes, the gauges all read high before replacement of fuel gauge, and I meant fuel, temp and oil press...dopey me....
