Drilling throttle plates?
#74660
06/16/08 08:46 PM
06/16/08 08:46 PM
When i try to adjust my carb with the idle mixture screws i dont see much change in idle or vac. readings The carbs are a 6 pac set up do you guys think I should drill the throttle plates? The car seems to run fine and idle about 1100 just doesn't respond to the mixture screws. What should I do ? THANKS for any help EDDIE B
Re: Drilling throttle plates?
[Re: BobR]
#74662
06/17/08 05:52 PM
06/17/08 05:52 PM
#74665
06/17/08 06:41 PM
06/17/08 06:41 PM
drop the idle to 800-900rpm. then see. 1100 is to high.
[Re: RobX4406]
#74667
06/17/08 08:33 PM
06/17/08 08:33 PM
rob,what do you mean how many tuning threads am i going to open? EDDIE B
#74668
06/17/08 08:38 PM
06/17/08 08:38 PM
i'm assuming the meglomaniac is wondering how many "how to tune" threads your gonna post.
#74669
06/17/08 08:48 PM
06/17/08 08:48 PM
Well I thought that was what this board was all about that guy can kiss my azz.
#74670
06/17/08 08:55 PM
06/17/08 08:55 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
You have a few open and keep asking the same question... it's a waste of time and best of luck to you if you don't want to keep it in one thread.
Greg, you feeling all right??? megalomaniac??? That's rich You still want those rear rails???
[Re: RobX4406]
#74671
06/17/08 09:11 PM
06/17/08 09:11 PM
I've never asked about drilling throttle plates,I guess everyone isn't as blessed as you and have all the answers.
#74672
06/17/08 09:17 PM
06/17/08 09:17 PM
RobX4406
And the title of this thread is what exactly????
If you don't have any other threads or asked a similar question elsewhere, I apologize. Seems I've seen you ask this in another thread.
You likely have an issue in another system on the car, not in the fuel system. You're trying to band-aid it with the carb. IMO, your combo should idle in the 800-900 range with 10-11" vacuum.
And the "Dan" crack has to do with something else.
[Re: mark7171]
#74673
06/17/08 10:47 PM
06/17/08 10:47 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
NO , you don't need to drill the throttle plates on street driven cars.
NO - drill - plate!
Drill as a last resort and you are not there yet. I was on the border of drilling plates and I was able to tune it out. Much happier now and no drilling.
[Re: RobX4406]
#74674
06/17/08 10:50 PM
06/17/08 10:50 PM
Rob.. i'm KIDDING buddy your one of the most stand up kinda guys i know.
