When i try to adjust my carb with the idle mixture screws i dont see much change in idle or vac. readings The carbs are a 6 pac set up do you guys think I should drill the throttle plates? The car seems to run fine and idle about 1100 just doesn't respond to the mixture screws. What should I do ? THANKS for any help EDDIE B
