68 Charger Hood Clearance #746238
07/12/10 07:28 AM
07/12/10 07:28 AM
NC
Sixt8Chrgr Offline OP
NC
Does anyone know if a 440 with a Eddy Performer intake with a 750 Holley and a stock breather will fit under a stock hood with hood insulation?
Thanks,
Lawrence
Re: 68 Charger Hood Clearance [Re: Sixt8Chrgr] #746239
07/12/10 10:34 AM
07/12/10 10:34 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
probably NOT, the clearance under a stock Charger hood isn't much. Anything that is much taller than stock hits.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 68 Charger Hood Clearance [Re: Sixt8Chrgr] #746240
07/12/10 11:22 AM
07/12/10 11:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Performer will but a RPM will not w/o a drop base.
Coming soon!!!!
Re: 68 Charger Hood Clearance [Re: Sixt8Chrgr] #746241
07/12/10 11:15 PM
07/12/10 11:15 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I think the Eddy Carter carb is a bit shorter as well, if you are going that direction..
Re: 68 Charger Hood Clearance [Re: sthemi] #746242
07/12/10 11:43 PM
07/12/10 11:43 PM
Minnesota
lukendan Offline
lukendan  Offline
Minnesota
In my last 69 Charger I had a 440/performer RPM/Eddy 750. It fit with the unsilenced air cleaner, but I needed to use a thinner air cleaner filter...
