Has anyone adapted a stock 2bbl air cleaner to a 4bbl? #746177
07/11/10 11:42 PM
07/11/10 11:42 PM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
I'm thinking about doing this on my 68 Charger which was originally a 383/2bbl/4 speed with the stock round snorkel air cleaner and it will be getting a Holley 770 4bbl carb. I'd like to retain much of the original appearance so I'm needing advice on how to make this adaptation.
1968 Charger 383/2bbl/4spd (1 of 74) 1994 Dakota Sport 3.9L/AT/2WD 2003 Durango SLT 4.7L/AT/4X4 Yes, all Dodges and nothing else
Re: Has anyone adapted a stock 2bbl air cleaner to a 4bbl? [Re: bull] #746178
07/11/10 11:54 PM
07/11/10 11:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Find a drop base air cleaner clearanced for the Holley floats; usually cheap at swap meets, $10-$20. Use filter height & diameter (diameter will likely be 14") you need, and put the stock lid over it. Add a nipple for the crankcase vent hose. Done.
If you need a smaller diameter, they exist but not often in drop-base style.
You might have room for a standard base, depending on your intake.
Or find an OEM bottom that'll work with your lid.
Re: Has anyone adapted a stock 2bbl air cleaner to a 4bbl? [Re: bull] #746179
07/12/10 01:05 AM
07/12/10 01:05 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Check and compare the filter for the 2bbl and 4bbl application , the non unsilenced air cleaner assembly , the filter MIGHT be the same , if that is the case all you need is the AVS 68 base .
Otherwise it shouldn't be hard to do what you propose, but I would make it like the unsilenced , meaning there is an opening between the OD of the filter and the top to give you the airflow you need .
Re: Has anyone adapted a stock 2bbl air cleaner to a 4bbl? [Re: JohnRR] #746180
07/12/10 03:50 AM
07/12/10 03:50 AM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
Thanks. I should mention, as stated above, that I'm using an Edelbrock dual plane manifold (the one that looks stock).
Re: Has anyone adapted a stock 2bbl air cleaner to a 4bbl? [Re: bull] #746181
07/12/10 07:00 AM
07/12/10 07:00 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Like said above, just use a drop base 14" with whatever height air cleaner and the 2bbl lid. works great, I've got one on a Holley 950.
Re: Has anyone adapted a stock 2bbl air cleaner to a 4bbl? [Re: Jeff_383] #746182
07/13/10 12:02 AM
07/13/10 12:02 AM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
Where's a good place to get a drop base?
Re: Has anyone adapted a stock 2bbl air cleaner to a 4bbl? [Re: bull] #746183
07/13/10 09:20 PM
07/13/10 09:20 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
AdvanceAutoParts is where mine is from.
