8 3/4 center chunk? #74591
06/16/08 05:52 PM
06/16/08 05:52 PM
Anonymous OP
Anonymous OP
I need to find a center chunk for my Duster,an I would like to get one with a date code that will work with the cars build date. Is there a date stamped on the chunk that I can look for ? or where they dated with a stamp ? which may not be visable anymore.
I`m thinking it would be dated anywhere from 2 to 8 weeks prior to the build date of the car, does this sound somewhat normal or not?
Re: 8 3/4 center chunk? #74592
06/16/08 06:12 PM
06/16/08 06:12 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
What's the build date on your car. I have a pumpkin out of a late built 71 car.
Re: 8 3/4 center chunk? [Re: RobX4406] #74593
06/16/08 06:57 PM
06/16/08 06:57 PM
Anonymous OP
Anonymous OP
Fender tag an broadcast sheet says C02, the sticker in the door says 11-69.
Re: 8 3/4 center chunk? #74594
06/17/08 08:44 AM
06/17/08 08:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
date code are CAST on the chunk itself , as long as its BEFORE your SCHEDULED production date you should be good .
i never paid attention to the dating spans of chuck casting to gear dating .
Re: 8 3/4 center chunk? [Re: JohnRR] #74595
06/17/08 10:23 PM
06/17/08 10:23 PM
Anonymous OP
Anonymous OP
Thanks John,It has always been something I`ve never really paid any attention either. Looking to put together a car to use for some pure stock fun, an while I`m at it might as well pull my hair out a little more am make the dates on things jive with the car since someone down the line took the all e-bag parts off of it .
