Drive shaft critial speed ? what you guys running #745865
07/11/10 09:02 PM
07/11/10 09:02 PM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
i talked with dyno tech about the drive shaft for the Demon and what RPM range it will live at.
Jim told me i needed a 5 inch Alum. shaft to over come the critial speed on the drive shaft @ the length i will need / 50 inch center to center
or go carbon fiber shaft.
just wondering what some of the high winding motors are running for drive shafts
with my small block shift 9,400 trap 9,800 is the plan
Bob
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745866
07/11/10 09:20 PM
07/11/10 09:20 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
high rpm my is 4 inch at 7200
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745867
07/11/10 09:26 PM
07/11/10 09:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bob I have a 4" moly... but its 39" and I have been
in the 9400 range a couple of times... normal is 8200
and its been in there for about 8 years now, still
with the same U-joints and it looked like new when I
had it out the other day
Re: Drive shaft critial speed ? what you guys running [Re: MR_P_BODY] #745868
07/11/10 10:09 PM
07/11/10 10:09 PM
sycamore,ohio
sycamore,ohio
@ 39" moly 4 inch the critical speed of your shaft would be over 10,000
the length is the important key to the formual.
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745869
07/11/10 10:42 PM
07/11/10 10:42 PM
Out West
408strokerdart Offline
Out West
Bob, Most of what I have found is that most driveshaft companies severely under estimate the true critical speed of a given material. I was suspect due to what I seen on the chart in Mark Williams catalog. I did the calculations myself and came up with much higher critical speed numbers than what was published. Had another engineer go over my numbers and verify them.
I ended up with a 49" long 4" diameter aluminum shaft. Shift at 8000, cross stripe at 8200. No probelms at all. I will revisit this soon as I will be going to a glide and the shaft length will be 56" long. I might have to go to an MMC material or carbon. I would guess you will be very close to having to run a carbon shaft at that length and RPM.
BTW, don't forget you will have lower shaft RPM than engine rpm (converter efficiency not 100%) so it will be just slightly lower than engine RPM. Maybe 500 RPM less?
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745870
07/11/10 11:15 PM
07/11/10 11:15 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
nice formula my is only 36 inch
Re: Drive shaft critial speed ? what you guys running [Re: 408strokerdart] #745871
07/11/10 11:21 PM
07/11/10 11:21 PM
sycamore,ohio
sycamore,ohio
Brain, the MMC bonded MW's shaft @ 4 inches is rated at 8,766 for the length i need,
its sfi 43.1 spec.
going to make a call to them about the shaft.
when i go to the Hemi and a 400 i will need a shorter shaft and need to find out if they can shorten the bonded ones
dont want to spend a grand twice on drive shafts
dyno tech doesnt offer the MMC ones anymore
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745872
07/11/10 11:28 PM
07/11/10 11:28 PM
408Dust Offline
408Dust  Offline
4 inch Aluminum, like you said length is a big factor in the equation.
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745873
07/11/10 11:29 PM
07/11/10 11:29 PM
Out West
Out West
its sfi 43.1 spec.
This is exactly why I went the budget route on my current shaft....probably going to have all of 25 runs on it when I swap to a glide and need another. $$ is the only reason I skimped/saved, but I won't feel as bad spending bigger money on the next one, plus it will be longer making the problem even worse.
I think they can cut the MMC shafts and bond in a new end as long as they shorten it at least 2-3". Good luck with it, can't wait to see how your car runs with that killer small block.
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745874
07/11/10 11:48 PM
07/11/10 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bob I am aware that the length is a MAJOR factor
thats why I stated the length.... Dyno tech build mine
Re: Drive shaft critial speed ? what you guys running [Re: MR_P_BODY] #745875
07/12/10 12:05 AM
07/12/10 12:05 AM
sycamore,ohio
sycamore,ohio
Raff, not sure why they dont build the MMC shafts anymore
they built the one i ran with the dana rear
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745876
07/12/10 12:25 AM
07/12/10 12:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think they sold all that many... they are pricey
so why buy all that stock and equipment to have it
sitting around taking up space... JMO.... Dynotech
isnt that far from me so I go and pick up my stuff
and that shop isnt all that big
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745877
07/12/10 08:06 AM
07/12/10 08:06 AM
Northern Territory, Australia
Z
Zapp Offline
Zapp  Offline
Z
I thought MMC was hard to come by so it got dropped
Re: Drive shaft critial speed ? what you guys running [Re: Zapp] #745878
07/12/10 11:59 AM
07/12/10 11:59 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Holy smokes 5" drive shaft
That wont even fit in the car will it?
Re: Drive shaft critial speed ? what you guys running [Re: BobsProFab] #745879
07/12/10 12:04 PM
07/12/10 12:04 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
in my Camaro..
Lukavich Matrix 4"..I've been at 8600 with a blower
the Duster uses a moly shaft 6800-7200
Re: Drive shaft critial speed ? what you guys running [Re: MR_P_BODY] #745880
07/12/10 01:14 PM
07/12/10 01:14 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
FORMULA
http://www.wallaceracing.com/driveshaftspeed.htm
using a 4" Strange with moly ends
home of the
Sox and Martin Hemi Duster
