Another W Tire Question
#744578
07/10/10 09:20 AM
07/10/10 09:20 AM
Posts: 1,532 off the grid
340B5
off the grid
I bought a set of W type Hoosiers for my Duster in the hope of having some wrinkle and squat on the rear and then getting up on the tire quicker.
In the only picture I saw from the track photographer that was useful to me for tuning purposes, they were not wrinkled @ 10 lbs pressure.
My question is: Do they tend to limber up after a few passes?
Yeah, it's got a smallblock.
Re: Another W Tire Question
[Re: 340B5]
#744579
07/10/10 10:23 AM
07/10/10 10:23 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
What was your sixty? What's the car weigh?
[Re: Bigcube]
#744580
07/10/10 10:39 AM
07/10/10 10:39 AM
340B5
off the grid
Car weighs 3180 w/driver. Old 60's were standard 1.64 w a best 1.62 with other tires which were about 29 3/4 tall. The new tires are 30 1/4 tall. Best 60 last t&t was 1.70 , but some might be my lack of seat time this year. Also 92* heat? Hoping to make 1.5? 60's. This is a nose heavy back half car. Lost some front end travel raising the front level w/ back, but I will be working on that today.
[Re: Bigcube]
#744584
07/10/10 11:16 AM
07/10/10 11:16 AM
340B5
off the grid
I didn't feel it spin. And as far as weight goes, the tires are 1 lb heavier than the old ones, but I took the tubes out, so the whole rotating mass is less. I don't like admitting it, but I'm thinking I could have lost some low rpm torque with my home porting job. I've gained .2 in ET, but the 60's are ugly. I'm hoping increased front end rise will help mash them the slicks down some. I might try higher launch rpm. Will these tires limber up some? Only 3 passes so far.
[Re: 340B5]
#744585
07/10/10 11:19 AM
07/10/10 11:19 AM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
what rear gear, ET,MPH and converter stall???
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
