freeze plug behind motor mount 1970 383 #744237
07/09/10 07:45 PM
07/09/10 07:45 PM
Anonymous OP
Anonymous OP
hey guys is there a freeze plug behind the motor mount on the driver side?it is pooring water from behind the mount and i am assuming it is from the freeze plug.also can i get the mount off by just unbolting it and jacking the motor up...thanks alot
Re: freeze plug behind motor mount 1970 383 #744238
07/09/10 08:01 PM
07/09/10 08:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes to both questions.
Re: freeze plug behind motor mount 1970 383 [Re: stumpy] #744239
07/09/10 10:40 PM
07/09/10 10:40 PM
Anonymous OP
Anonymous OP
thanks stumpy...i owe you one!!!!
Re: freeze plug behind motor mount 1970 383 #744240
07/09/10 11:02 PM
07/09/10 11:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When you remove the mount be sure to take note of which side of the block ears it's mounted on.
