63 Dodge alloy radiator? #743950
07/09/10 08:03 AM
07/09/10 08:03 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Does anyone know of a direct fit aluminium radiator for a 63 Dodge B body big block? I'm after something that has the top tank that looks like the factory radiator, that could be painted black and pass as a factory radiator at a glance. Would also have to use the factory mounts and mount the factory shroud.
I've seen that Be Cool make this sort of radiator for GM A bodies, anyone make such a product for Mopars?
Re: 63 Dodge alloy radiator? [Re: slantman] #743951
07/09/10 09:23 AM
07/09/10 09:23 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Re: 63 Dodge alloy radiator? [Re: smokinwoody] #743952
07/09/10 09:39 AM
07/09/10 09:39 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
Thanks for that, however I can get a radiator like that here in Australia.
What I'm after is something that looks like the original radiator, with the stamped top tank. Something like this from Be Cool:
Re: 63 Dodge alloy radiator? [Re: slantman] #743953
07/09/10 09:45 AM
07/09/10 09:45 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I have a BE-COOL in my Camaro...I hate it..cant cool my sb with a blower even with 4 spal fans on it...
worse investment I ever made on overpriced junk..
look at those Champions...they are all welded and they are guaranteed..
the other one I like is in my Duster...thats a Northern Dual pass...thats an awesome radiator too
Re: 63 Dodge alloy radiator? [Re: slantman] #743954
07/09/10 09:47 AM
07/09/10 09:47 AM
AndyF Offline
AndyF  Offline
Try the guys at Griffin.
Re: 63 Dodge alloy radiator? [Re: AndyF] #743955
07/09/10 10:12 AM
07/09/10 10:12 AM
Down under
slantman Offline OP
slantman  Offline OP
Down under
That's what I'm after, thanks Andy. Is that a custom job, or do you have a part number for it?
Re: 63 Dodge alloy radiator? [Re: slantman] #743956
07/09/10 06:23 PM
07/09/10 06:23 PM
AndyF Offline
AndyF  Offline
It is a standard part number.
I ordered mine with an oil cooler in the lower tank which was an option. Most people put a tranny cooler down there or no cooler at all but I wanted an engine oil cooler.
Re: 63 Dodge alloy radiator? [Re: AndyF] #743957
07/09/10 10:26 PM
07/09/10 10:26 PM
IN
ahy Offline
ahy  Offline
IN
Mancini also offers a stamped top tank aluminum radiator, 22" and 26". I'm running the 26" with great results with a 496 B.
Re: 63 Dodge alloy radiator? [Re: AndyF] #743958
07/10/10 10:02 PM
07/10/10 10:02 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I sent Griffin my radiator out of my 66 Satellite to copy. They installed a trans cooler in the bottom for me to use in my 66 Hemi car I had them make it 2 rows 1 1/2" for a total of 3" thick--It works!!! I did this around 1998. .
