Re: MSD/Mallory boxes really necessary?
[Re: babarracuda]
#74382
06/16/08 09:05 AM
06/16/08 09:05 AM
Posts: 4,085 Indiana
W5Duster436
Indiana
The Malory Unilite works good with CDI boxes. The advantage of multi spark ignitions is easier starting and how they run when the motor is cold. I have noticed improved part throttle response. As far as performance is concerned, my friend ran a Mopar ignition for years racing a 11:1 340 motor and it ran great.
On my street car, I only run CDI (Crane HI-6 or Mallory. Many prefer MSD, but I have not had great luck with the MSD 6. Just my preference.
I was looking at the 32 series in hyfire 6-AL. Just want to be sure that it was something worth the extra $. I wasn't sure that the unilite worked with the hyfire box if I chose to buy it later. I think if you buy the 32 series distributor you MUST run the box.
[Re: W5Duster436]
#74384
06/16/08 09:53 AM
06/16/08 09:53 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DaytonaTurbo]
#74387
06/16/08 11:26 AM
06/16/08 11:26 AM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
I like the chrome box and adj. dist. you can put in any curve you want. i have read many times in Mopar Muscle that the stock Mopar setups were all we needed.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
[Re: 65cuda]
#74388
06/16/08 11:31 AM
06/16/08 11:31 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Necesary ? no... depending what use you will have to the car. I'm very happy with Mopar Chromed box and stock dist, with MSD Blaster 2 coil ( same than MP coil )
I think MP stuff in this case works GREAT for the price
[Re: W5Duster436]
#74389
06/16/08 11:31 AM
06/16/08 11:31 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The main advantage of the MSD is the multiple sparks at low RPM. When you start getting into big cams, big heads, carburated engines, the air/fuel mixture at idle and low rpms can vary alot and the multiple sparks reduces the chance of the cylinder not firing. At higher RPM, the MSD boxes just provide a single spark (your limited by the cap and rotor design), but by then there is good intake velocity so the air/furl mixture will be more conistant.
The new OEM coil-on-plug design allows much longer spark duration with out the possability of flash over that you could get from the cap and rotor design, which brings up the issue of rotor phasing.... anyhow, thats another post.
Anyhow if you have a near stock engine or fuel injected engine there probbably won't be a big improvement with the MSD. If you have a modified carburated engine you could see some improvements, usually easier starting, more even idle, and better low rpm response.
[Re: W5Duster436]
#74390
06/16/08 02:30 PM
06/16/08 02:30 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
I run one. Noticed a bit better idle quality and throttle response. Really, they allow a greater margin of error for those of us who can't tune very well, like myself. From what I gather, a properly setup stock ignition on a mild motor will perform just as well.
Where they really start to shine is with all the add-ons and goodies that was stated before, timing controllers, rev limiters, etc... The rev limiter in my 6AL saved butt once already...
[Re: Neil]
#74392
06/16/08 08:11 PM
06/16/08 08:11 PM
W5Duster436
Indiana
thanks for all the input. I went ahead and bought the mallory and Hyfire 6AL since it has a bit more output than the msd setup.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: W5Duster436]
#74393
06/16/08 09:13 PM
06/16/08 09:13 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I like my 6AL box. Nice to have a rev limiter with a stick car in case I break something while racing it or getting on it.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: W5Duster436]
#74395
06/16/08 09:25 PM
06/16/08 09:25 PM
Posts: 8,165 Left Coast
BobR
Left Coast
That's one of the reasons I decided to go ahead and get it. never know when you're gonna miss that next gear. lol
You will need it sometime but in the mean time the confidence it gives you will make you a better driver. -Bob
[Re: 451Mopar]
#74396
06/16/08 10:35 PM
06/16/08 10:35 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
... At higher RPM, the MSD boxes just provide a single spark (your limited by the cap and rotor design), but by then there is good intake velocity so the air/furl mixture will be more conistant. ...
Spot on information; the limiting factor is the duration of the sparks produced vs the time available to spark a cylinder given the rotational speed. Once you reach a certain RPM its time to fire the next cylinder before you could spark a cylinder a second time. A better cap and rotor design might help, but unless you make shorter duration sparks, you can't fit more into a given amount of time.
I used a Crane CD unit 30 years ago and had a noticeble difference on my 71 Charger. I'll probably buy a Crane unit again soon as I like the built in rev limiter. BTW, a recent issue of the Summit catalog had a great comparison of specs on MSD,Crane, Mallory, Accel, & Summit units. Unfortunately I can't find it in my current catalog.
[Re: DaytonaTurbo]
#74397
06/16/08 10:52 PM
06/16/08 10:52 PM
Necessary? No of course not. Do they help? Some swear by them, others say they do nothing.
i'm a firm believer in that they do nothing. one good spark at the RIGHT TIME is all a engine needs.
[Re: W5Duster436]
#74398
06/18/08 09:27 PM
06/18/08 09:27 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
You should love it I have a mallory hyfire box on my duster drag car and couldnt be happier with it. It went from points (which suck and I wouldnt run them on anything) to the mopar electronic ignition setup which isnt bad to the mallory hyfire box. It made a dramatic difference in how the car started,idled,and noticeably better throttle throttle response. Im not saying it works miracles but Im pleased. It also is lower priced than the msd and takes less current draw to run,no rev chips to worry about,and if you want to place it on a /6 like I did you can reuse it later on a v8 car unlike an msd which if you set it up for a 6 cylinder to bad you'll have to keep putting it on a 6 or whatever it's setup for. Mallory is a better buy IMO, I had an msd and had problems with it but maybe I just got a bad one?
Yes some of us here do modify /6's ![](/ubbthreads/images/graemlins/grin.gif)
