wheel cly???, OEM 68 vs the new ones #743829
07/08/10 11:49 PM
07/08/10 11:49 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
is there a dfference between the oem 68 dart wheel cly vs the new replacement ones?
Re: wheel cly???, OEM 68 vs the new ones [Re: Dakota_Don] #743830
07/09/10 12:08 AM
07/09/10 12:08 AM
I think the replacement ones will be a larger bore than oe. Eberg may have 7/8" ones for you
Re: wheel cly???, OEM 68 vs the new ones [Re: RapidRobert] #743831
07/09/10 05:36 PM
07/09/10 05:36 PM
Alton, IL
Alton, IL
the ones i found to replace mine ( advancedauto) are 15/16..
im not sure of my originals sizes as of yet (still on car).
Re: wheel cly???, OEM 68 vs the new ones [Re: Dakota_Don] #743832
07/09/10 05:48 PM
07/09/10 05:48 PM
Alton, IL
Alton, IL
68 dodge monaco uses 7/8 wheel cly.. wonder if they will work..humm guess ill go compare them and see. will going to the smaller wheel cly cause my rear to brakes to lock easier??
