Re: need help bench 4 speed b-body(71) [Re: SNK-EYZ] #743824
07/09/10 11:18 PM
07/09/10 11:18 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
ok hm it is my uderstanding that the the 1/2 pod was the one closet to the front of the motor and 3-4 being top back bottom if that is corect then the way i have it in the above pic is wrong as i qot the longest rod (going to top and closet to the motor pod (for lack of a better word)) on the finger close to the driver
and the top close to driver going to the middle finger
i tried swaping them around and have them like you said long rod in the middle but rods would bind up so swaped back
i bought this whole setup togeather out of a bench seat 4 speed car
now for the lineing up the pin i seen that run a small bolt or something all the way threw but then just what am i adjusting and with what after i did that?
man it sure would help if i had a clear pic showing side of tranny with rods on lol
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: need help bench 4 speed b-body(71) [Re: toplescuda] #743825
07/09/10 11:45 PM
07/09/10 11:45 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
The front shift boss on the trans is definitely the 3/4 one.
The rear one is the 1/2 one.
Use the largest bolt that will fit in the shifter to lock the 3 arms in place (at the bottom of the shifter) and you spin the shift rods and get them to fit right on the shifter studs on the trans while it's in neutral. If the don't drop right on, turn the rod more till they do. Then secure them to the side of the trans (one at a time).
Re: need help bench 4 speed b-body(71) [Re: SNK-EYZ] #743826
07/10/10 09:35 PM
07/10/10 09:35 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
got the shifter rods all lined out some were like 6-7 full turns its all on there right i dont have a tranny mount so got the trans proped up so its not setting on the fingers thank a million for the help
ralph
1971 charger
