Re: Cam advice needed
[Re: AK_JH27]
#743611
07/08/10 04:56 PM
07/08/10 04:56 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Do you know your compression ratio? Or how far the pistons in the hole? if it is mostly stockish, I would use the bigger Summit cam.
[Re: AK_JH27]
#743615
07/09/10 01:05 AM
07/09/10 01:05 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I need to get a new cam for my 440 wondering what you guys would get.
Here is my combo:
Performer RPM manifold 750 cfm edelbrock headers 3:55 gears 727 w/2500-3000 stall (i think, cant seem to remember acutal )
stock heads/valves/springs/rockers
Here is what i had before the cam failure. dont want to post brand.
Power Range 1500-4500 Valve Lift Int/.420 Exh/.443 Dur. @.050 Int/ 204^ Exh/ 214 Adv. Dur.Int/ 270^ Exh/ 280^ Lobe Center Int/107^ Exh/ 117^
^is supposed to be degrees dont now how to do the little o next to the number
let me know
That was a really small cam for a 440! The Voodoo 60302 or 60303 would be good and they are priced good too, $210 for cam and lifters through Summit Racing.
[Re: DaytonaTurbo]
#743620
07/09/10 08:38 AM
07/09/10 08:38 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
what car, how heavy?
I'd go with a comp XE268 or lunati voodoo 60403, and use comp #911 springs. lighter car, I'd maybe look at an XE274.
when you put the new cam/lifters in, mark each lifter on top with a sharpie, and turn it over by hand to make sure they rotate.
