msd ignition install #743481
07/08/10 10:35 AM
07/08/10 10:35 AM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
Looking for some help on installing an MSD 6al box on my 360. Anyone have any pics of where a clean place to put it is. I am thinking the fire wall. I am also putting an MSD distributor but I'm not sure if I should do it myself. Any comments would be helpfull. The car is a 70 Challenger. Thanks
Re: msd ignition install [Re: rtrag] #743482
07/08/10 10:46 AM
07/08/10 10:46 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Easy to install
Just get the right size wires and solder them in.
Good ground and battery connections.
Mine is an A Body BB but here is where I put it.
Re: msd ignition install [Re: DAMOPARS] #743483
07/08/10 01:27 PM
07/08/10 01:27 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've heard of some guys mounting them under their battery tray. I've heard of other guys mounting them under their dash inside the cab.
Re: msd ignition install [Re: rtrag] #743484
07/08/10 07:51 PM
07/08/10 07:51 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Definitely something your entry level mechanic can accomplish. Just follow the instructions Distributor has good instructions too. Will plug right into the MSD box green and purple wire connection.
Re: msd ignition install [Re: Alikazam] #743485
07/08/10 10:07 PM
07/08/10 10:07 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
pic of mine on the firewall on my 70 cuda,think I might move it someplace unseen. real easy to wire up.
Re: msd ignition install [Re: stinger] #743486
07/09/10 01:27 AM
07/09/10 01:27 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
That's where mine started out for the first 5 years or so. I moved it under the dash 2 or 3 years ago. The unit keeps cooler inside, as opposed to getting all the underhood heat, which should make it last longer. At least that's what I'm thinking...
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: msd ignition install [Re: rtrag] #743487
07/09/10 03:59 AM
07/09/10 03:59 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Easy to do, especially with their distributor - follow their excellent instructions. Easy upgrade for the first timer.
Ride eternal, shiny and chrome
