The culprit- 98 Dodge 3500 van 5.9 with 190,00 miles.
Gremlins- intermittent rough idle, mega skipping, shuts off, engine light, multiple misfire codes,downsteam o2 sensor codes,crank sensor codes- ALL INTERMITTENT! Terrible mpg and power when these are going on.
What we've done and replaced-
Compression test-good on ALL 8
Removed,checked,cleaned injectors
New O2 sensors,crank sensor,map sensor, IAC valve,plugs,wires, distributor, computer,coil,intake gaskets,cat converter and muffler. Checked all electrical connections,battery cables,etc.
All the codes are gone now but the misfire codes- random on all cylinders, no rhyme nor reason. Seems to cut off when engine temp reaches about 195-200- then will not restart- let it sit for almost 5 minutes exactly everytime- refires and runs great- (cuting off when it goes from open to close loop is our guess?) The problems have gone on randomly for 3 months, thru 3 computers. (2 used,1 new) Here's the kicker- put a 97 5.2 1500 computer on it- runs great! Still cuts off, but not as much- more power and better mpg- but no guages, speedometer,etc, and won't pass inspection of course. We are stumped and beyond frustrated.
Any help?
Thanks in advance!!!
