Re: school me on intial and total timing
[Re: swinger73]
#742736
07/07/10 04:13 PM
07/07/10 04:13 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
Depending on your engine, your initial timing at idle should be anywhere between 12 and 20 degrees BTDC. As your rpms increase, your timing advances (due to the internals of your distributor). At some point (this should probably be between 1500 and 2500 rpm) this advance stops and at this point you have your "total timing" which should be around 36 to 40 degrees. I hope this helps. Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#742738
07/07/10 04:41 PM
07/07/10 04:41 PM
DaytonaTurbo
Manitoba, Canada
Initial timing is set at idle. Total timing is set at whatever rpm the distributor is setup to stop advancing at. An stock distributor may only stop advancing at 4000rpm where an aftermarket or recurved stocker may hit total advance at 2500, 3000, or whatever rpm the guy doing it set it up for. All timing is set with the vacuum advance can on the distributor disconnected. Vacuum advance comes in on top of total timing.
At idle the distributor's shaft is turning so slow, not enough force is present to start operating the mechanical advance mechanisim inside the distributor(which is weights and springs slung outward by centrifugal force), or at least not operating it very much. This is where you set your initial timing by rotating the distributor. A stocker might like 10* initial timing where something with a big cam might like 20* initial.
Total timing = initial + mechanical advance. Mechanical advance is however much timing is built into the distributor. This can be tailed to suit your engine. Some stock distributors have 30* of advance built into them where other recurved distributors can have 20, 10, or however many is wanted. So if you have an engine with a big cam, you might hypothetically have 18* initial + 18* mechanical advance = 36* total timing all in by 2800rpm.
If your distributor is curved wrong for your engine, you will never have it right. Too many guys think you can just plop a distributor on out of the box and go. You can not. They need to be tuned for your application.
[Re: burdar]
#742741
07/08/10 12:00 AM
07/08/10 12:00 AM
DaytonaTurbo
Manitoba, Canada
I've never understood why the advance should be all in by 2500-3000 RPM. Shouldn't the timing continue to advance as engine speed increases?
Yes modern efi cars do as you suggest, keep increasing timing with rpm all the way to redline. However the rate of advance also changes a lot and as the rpms climb, the rate the advance increases goes down significantly. Something like that would be very difficult to make a distributor do. I'm gonna go out on a limb and say it can't make much difference if nobody is doing it on our old motors. Also, a lot of race guys run fixed timing distributors with a retard dial on their spark box so they can start it, then crank up to full advance at all times. I don't think those guys would be doing that if they were leaving hp on the table.
