Electrical ...HELP #742698
07/07/10 01:38 PM
07/07/10 01:38 PM
DELAWARE
bee71mopar Offline OP
DELAWARE
My interior lights are coming on when you close the door instead of when you open the door.Is it the door switches or the dome adjuster light switch?
1969 Plymouth Fury Convertible
Re: Electrical ...HELP [Re: bee71mopar] #742699
07/07/10 01:44 PM
07/07/10 01:44 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Both doors or just one door? The switches are are ground switches so most likely the switch is grounding out when the door is closed
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Electrical ...HELP [Re: bee71mopar] #742700
07/07/10 01:48 PM
07/07/10 01:48 PM
DELAWARE
DELAWARE
Both doors!!!! I open one or the other or both doors the light goes out when i open the doors
Re: Electrical ...HELP [Re: bee71mopar] #742701
07/07/10 01:50 PM
07/07/10 01:50 PM
DELAWARE
DELAWARE
And the one under the dash...The round one dims...It stays on just dims
Re: Electrical ...HELP [Re: bee71mopar] #742702
07/07/10 02:12 PM
07/07/10 02:12 PM
So Cal
So Cal
Sounds like power is going to both sides of the circuit.
What happens when you remove the dim bulb?
Re: Electrical ...HELP [Re: HealthServices] #742703
07/07/10 02:18 PM
07/07/10 02:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Has this just started? If it has what have you done to the car most recently?
Re: Electrical ...HELP [Re: stumpy] #742704
07/07/10 02:27 PM
07/07/10 02:27 PM
DELAWARE
DELAWARE
Didnt really notice before I did a little resto on the car had the dash out to put some speakers in the dash..Checked all the connectors to make sure I plugged everything correctly..but there where no lights in the back lights that keep coming on when the doors are closed..Now the 20 amp fuse keeps blowing..The panel fuse..
Re: Electrical ...HELP [Re: bee71mopar] #742705
07/10/10 01:23 PM
07/10/10 01:23 PM
DELAWARE
DELAWARE
Well I changed the dimmer switch and put the right bulb in the side interior lights...Seems to be working correct now ( must of been the dimmer)..passenger light not working now have to trace it later..Working on putting new leaf spring bushings in now instead of going to Carlisle.. How FUN...
