Post deleted by Defbob
[Re: RockChip]
#742132
07/06/10 08:54 PM
07/06/10 08:54 PM
[Re: RockChip]
#742134
07/07/10 03:09 AM
07/07/10 03:09 AM
Re: Gonna build some log manifolds HELP!!!!!!!
#742135
07/08/10 07:06 PM
07/08/10 07:06 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Durability will be the problem, not power output. You will go crazy repairing cracked/ warped logs. You dont have a symetrical port spaced hemi. Your center ports will give you more grief than most are willing to put up with. Do yourself a favor and listen to what "everyone else" says.
[Re: TRENDZ]
#742136
07/08/10 10:16 PM
07/08/10 10:16 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My hot rod is an exhaust leak from hell. I can't keep gaskets in it and have had to repair a few cracks too. My logs use 1/2" flanges.
[Re: CokeBottleKid]
#742143
07/10/10 07:54 AM
07/10/10 07:54 AM
feets
Senior Management
Senior Management
Irving, TX
Copper gaskets blow out too.
I have the ability to create an exhaust leak after the first sustained boost run. Yeah, the logs are warped.
[Re: Twostick]
#742145
07/11/10 11:15 AM
07/11/10 11:15 AM
feets
Senior Management
Senior Management
Irving, TX
They are "seasoned" enough that cracks are popping up here and there.
[Re: DusterDave]
#742148
07/11/10 02:16 PM
07/11/10 02:16 PM
feets
Senior Management
Senior Management
Irving, TX
Bingo! Metal was too thin. I should have used weld els.
[Re: feets]
#742149
07/11/10 08:08 PM
07/11/10 08:08 PM
TRENDZ
Milwaukee WI
No. They will continue to shrink and harden no matter how used, or how thick they are. You plain and simply need room for expansion and contraction. If you build them so strong that they wont move, you end up first breaking studs. Then, after putting in larger studs, you eventually crack the head. If you make logs and expect them to last you MUST put slip joints in between the ports.
[Re: TRENDZ]
#742150
07/12/10 11:46 AM
07/12/10 11:46 AM
feets
Senior Management
Senior Management
Irving, TX
I built the flanges with oversized stud holes with that in mind. In the past, I cut the flanges between the center and outboard ports. It didn't seem to help that much since the headers were already trashed. My current flanges are not cut.
