NE1 using a weiand 8007 #742090
07/06/10 05:34 PM
07/06/10 05:34 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
how would this intake be in a 400 hp 360? looks like the runners are large but neck down at the head, i would gasket match and maybe use a t-quad with this, home ported 2.02 j's, i usually shift at 6K.
Re: NE1 using a weiand 8007 [Re: ademon] #742091
07/07/10 12:21 PM
07/07/10 12:21 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
They are decent manifolds. Do a port match for a 340/360 (last inch or so of runners) and it should work well.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: NE1 using a weiand 8007 [Re: ademon] #742092
07/07/10 05:04 PM
07/07/10 05:04 PM
Lehigh Acres, Florida
rickstershemi Offline
We're running one on my son's 84 dodge 360, primarily stock moder with XE268H Comp Cam and a 600 vac secondary....very responsive, going to try a 750 vac secondary I just picked up....I was very pleased with it
Rickster
Re: NE1 using a weiand 8007 [Re: rickstershemi] #742093
07/08/10 12:03 AM
07/08/10 12:03 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Ok, cool thanks
