A couple 69 RR questions
#742084
07/06/10 05:31 PM
07/06/10 05:31 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
OK this is more simple stuff for you guys. First, does the fuse block face into, or away from the glove box? Does the mounting screw tap into the plastic, or fasten with a nut? I have a 68, but it is totally different. On the steering wheel, is there supposed to be an insulator to keep the ground ring from shorting to the wheel? This one is shorting out and blowing the horn. I know the owner had the wheel restored and I am not sure how it is supposed to be.
Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: A couple 69 RR questions
[Re: NV69B7RR]
#742086
07/06/10 11:56 PM
07/06/10 11:56 PM
Hemi Allstate
Mt. Eden Ky.
Hmmm....I guess that the bracket next to the glove box is for something other than the fuse block. This is a new harness and there are no threads in the block. The steering wheel is black plastic with a horn ring and bird center.
Thanks, Mark
