gas gauge #742080
07/06/10 05:25 PM
07/06/10 05:25 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
I just finished restoring my 70 convert and the gas gauge won't work now. Any suggestions
Re: gas gauge [Re: rtrag] #742081
07/06/10 05:31 PM
07/06/10 05:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Make sure the sending unit is grounded. Do a google search here for gas gauge. You will find all kinds of info.
Re: gas gauge [Re: stumpy] #742082
07/06/10 10:07 PM
07/06/10 10:07 PM
70duster340 Offline
70duster340  Offline
Make sure that all the grounds are in place. My Duster had the same issue, and when I replaced all the grounds, the guage bagan working again.
Re: gas gauge [Re: rtrag] #742083
07/07/10 06:47 AM
07/07/10 06:47 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
ground the feed at the tank...turn key on..gauge will deflect to full if ok....if it does...wire/ground problem...if not...gauge went south
