Tunnelram 440 #742048
07/06/10 05:02 PM
07/06/10 05:02 PM
New York
badwedges Offline OP
New York
Im thinking of using 660 center squirter is this a good choice?
Re: Tunnelram 440 [Re: badwedges] #742049
07/06/10 05:04 PM
07/06/10 05:04 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
I would prefer 750 dps for street or race.
Re: Tunnelram 440 [Re: badwedges] #742050
07/06/10 06:50 PM
07/06/10 06:50 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
i ran 600 vac sec ,660 center squirtes , and 750 DP
the 750's worked best
WAXER
Re: Tunnelram 440 [Re: 572B1] #742051
07/06/10 06:51 PM
07/06/10 06:51 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I agree. The 660's were designed back when there was no such thing as a doublepumper carb and tunnelrams were the size of mailboxes. The fast cars that used 660's required extensive carb mods that are not needed with the DP's.
Re: Tunnelram 440 [Re: GomangoCuda] #742052
07/06/10 06:53 PM
07/06/10 06:53 PM
I have two 750 DPs for mine
Re: Tunnelram 440 [Re: ] #742053
07/06/10 07:25 PM
07/06/10 07:25 PM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Double pumpers all the way !!!!!!
Anular boosters if you can afford them
Re: Tunnelram 440 [Re: badwedges] #742054
07/07/10 09:06 AM
07/07/10 09:06 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
If you have 'em or can get reasonable, not bad choice.
Work ok for my 451 but havent tried bigger either.
more than enough power and the price was right.
Re: Tunnelram 440 [Re: theclutcher] #742055
07/07/10 11:43 AM
07/07/10 11:43 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I've had 625 Carters, 600 vac. sec.s, 750 vac. sec.s, and now just put a set of worked 660's on mine. Haven't had a chance to try it out yet, but the 600's sucked big time, 750's didn't work well either. The 625's worked nice. Now like I said the 660's haven't been run much yet. As yoy can see in the picture, they are really worked over. Throttle response seems good, but like I said I really haven't driven it much yet. Let alone run it at the strip.
Re: Tunnelram 440 [Re: badwedges] #742056
07/07/10 11:53 AM
07/07/10 11:53 AM
Yes
Re: Tunnelram 440 [Re: Cab_Burge] #742057
07/07/10 03:13 PM
07/07/10 03:13 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yes
No...Because there is only one squirter per carb. Its really not enough fuel shot with that much plenum volume to get the car moving without stumbling a little. You would be far better off with a single plane and just a double pumper. The old school crap can work, but not like the modern annular carbs with all the jettable air bleeds and such. If you do it, you will wish later you had spent the few extra bucks for real carbs instead of buying them twice.
Re: Tunnelram 440 [Re: Dragula] #742058
07/07/10 04:30 PM
07/07/10 04:30 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
Yes
with all due respect, i can make the 660's work without a lot of hassle. but, i do prefer a set of 750's
Re: Tunnelram 440 [Re: tjmarcus1] #742059
07/07/10 04:41 PM
07/07/10 04:41 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The 2 750 dp carbs will work great.Mill choke air horns off,block off power valves sq jet # 80 and you will have it close.
The Tunnel-Ram maybe o'll school but its faster.
I found out the Hard Way the Trick of the week stuff never works. Unless your have extra $$$ to throw away.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Tunnelram 440 [Re: MRMOPAR622] #742060
07/07/10 06:40 PM
07/07/10 06:40 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I guess i will be the oddball one. I will be using 2 carter comp 750 carbs on my 440.I know everybody does not like them. but i went 10.50 at 127 in my old 3500 pound 11.1 compression 440 powered 65 Plymouth and they were box stock.I would love to try some 750 dp on my car but i don't have the money to switch everything over to Holley. I say if you already have the 660 to give them a try. best of luck Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Tunnelram 440 [Re: mopar65] #742061
07/07/10 07:24 PM
07/07/10 07:24 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
anyone here that says the 660 center squirters wont work, either hasnt run any or has poor tuning skills period.
They work, and work well.
I will say they arent much for tuning, and jetting alone doesnt help much. But they work near best right OOTB or factory specs.
Re: Tunnelram 440 [Re: Bob_Coomer] #742062
07/07/10 07:46 PM
07/07/10 07:46 PM
illinois,u.s.
beezer Offline
beezer  Offline
illinois,u.s.
I ran a set of 660 center squirts on my 452 RB for years. They were done by Chuck Nuytten. I had them on a 3400 lb. Super Bee, a 2200 lb. 33 Ford 5 window coupe and a 1900 lb dragster. In all the years I ran those carbs I didnt change the jetting in them more than 3 or 4 times and after I changed it I came right back to where it had been when I started.
Re: Tunnelram 440 [Re: badwedges] #742063
07/07/10 07:49 PM
07/07/10 07:49 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
you could also go with EFI....
Re: Tunnelram 440 [Re: badwedges] #742064
07/07/10 08:08 PM
07/07/10 08:08 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
A friend of mine ran 9.60's with a 316 SBC with a pair of 660's in a 3,100lb Nova. I'd say they work
Re: Tunnelram 440 [Re: Dart1031] #742065
07/07/10 09:03 PM
07/07/10 09:03 PM
mo
moparbud Offline
moparbud  Offline
mo
two 750 dp
Re: Tunnelram 440 [Re: moparbud] #742066
07/07/10 09:15 PM
07/07/10 09:15 PM
mopar65 Offline
mopar65  Offline
two 750 dp
hey cool looking pic of your engine. what kind of car is it in, engine size, what et does it run? also what part of mo do you live in? do you race at ozark international raceway? thanks Mopar65
Re: Tunnelram 440 [Re: Bob_Coomer] #742067
07/08/10 09:13 AM
07/08/10 09:13 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I think so to.
The F/A record holder has em on his ride.
8.0 ets.
