72 barracuda 383 770 avenger 3/8 fuel line dp4b 1" spacer comp cams nostelgia 239 246 @50 484 484 lift hyd .Fram canister fuel filter.
After an intermittant problem of not restarting at bad times till it sat awhile ,My car finally wouldn't start when cold and at home.The fuel pressure gage showed 0 psi.I unhooked the line at the carb ,cranked,no gas.Ok, replace very new carter street strip 9psi pump with a new holly pump and 0 gas at carb. scratch head? Start to loosen input line on 25$ regulator and gas blowes out everywhere.Regulator decided to completly stop flow. I removed regulator, car runs super in garage.No flooding.Holley book says 7 1/2 psi max .Holley mechanical Pump is at 8psi, carter pump was 9 psi. Should I let thin
gs as is ??or will I have problems and need to install a good regulator??
