318 Front Seal #741276
07/05/10 11:11 PM
07/05/10 11:11 PM
Arizona
'Tink Offline OP
'Tink  Offline OP
Arizona
Is the front seal in the timing cover of a 318 from a 98 Dodge Ram 1500 supposed to be profiled to the face of the timing cover or flush?
Re: 318 Front Seal [Re: 'Tink] #741277
07/05/10 11:14 PM
07/05/10 11:14 PM
jacksboro,tn
1bad318 Offline
1bad440
1bad318  Offline
1bad440
jacksboro,tn
i would say flush
Re: 318 Front Seal [Re: 1bad318] #741278
07/08/10 01:15 PM
07/08/10 01:15 PM
Arizona
'Tink Offline OP
'Tink  Offline OP
Arizona
Most people do, which has turned out to be the problem. In this particular application there is a ridge inside the timing cover. There is a receiving lip in the seal. When the two meet STOP, trying to make the seal flush to the face will damage the seal because this particular one is supposed to be profiled at 4.0mm above the face.
Re: 318 Front Seal [Re: 'Tink] #741279
07/08/10 07:56 PM
07/08/10 07:56 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Correct, the bottom of the seal retainer will bottom out in the timing cover before it is flush on the outside.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
