70 Hemi Cuda parts list
#741268
07/05/10 11:07 PM
07/05/10 11:07 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
Hey Guys is there a master list in the archives anywhere for 70 hemi cuda specific parts/numbers like the one we had going for the A-12 cars ???
Thanks Shawn
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
Re: 70 Hemi Cuda parts list
[Re: Snoopy]
#741270
07/06/10 09:03 AM
07/06/10 09:03 AM
smac77
Caledon, Ontario
The only differences between a Hemicuda and a 440 Cuda is the engine assembly, k-frame, brake master cylinder assembly, engine bay wiring harnesses, transmission and exhaust system.
I know most of the parts are interchangeable, and the above parts you mentioned would be a good start (with part numbers for individual components within the assemblies you listed), but maybe I should re-phase the question to:
"I was wondering if there was ever a list done for part numbers a hemi cuda would have to have to be correct".... other than date codes of course, thats my secondary problem with an october '69 built car! I'm not looking to start another "concourse" debate here, I'm just rounding stuff up for the resto of the white hemi cuda I posted about a few months ago.. It's missing almost everything except the numbers matching engine! It even has a space saver spare... from a GM
I'm looking for hemi specific and the interchangeable part numbers a hemi car would have... for example: a 956 rad, trans oil cooler (auto), distributor hold down bracket, DP distributor, linkages, carbs, brake booster, shaker hood, base and components, the bigger 489 8 3/4 dif case etc, etc, etc.... if you break it down there are quite a few little bits and peices, I have allot of the numbers already and can get the rest with some digging, but, it would be much faster if this was previously discussed and a list was available already so i can fill in all the blanks quickly for all the little stuff I need ????
[Re: smac77]
#741271
07/06/10 09:11 AM
07/06/10 09:11 AM
smac77
Caledon, Ontario
another note: if anyone knows of the 69 B -body VIN .....9G232569 (jan 22, '69 built) This cuda has that cars original hemi torqueflite...
[Re: Snoopy]
#741273
07/06/10 04:36 PM
07/06/10 04:36 PM
smac77
Caledon, Ontario
Your best bet would be a 70-71 Factory Parts Book. It is available on CD or printed copy on eBay. That will give you all the part numbers plus exploded views of the assembles.
yeah, that was my next step...
[Re: JRepucci]
#741275
07/07/10 08:31 AM
07/07/10 08:31 AM
smac77
Caledon, Ontario
Here is a short list of the important parts
4742 front carb, all 4745 rear carb, manual 4746 rear carb, auto 2806070 fan clutch 2875987 dist, manual 2875989 dist, auto 3418453 LH exhaust manifold(casting number) 2780508 RH exhaust manifold(casting number) 2998956 radiator
Thanks for the info...
