Cooling Question??? #740637
07/05/10 01:32 AM
07/05/10 01:32 AM
Minnesota
lukendan Offline OP
lukendan  Offline OP
Minnesota
69 Charger w/ 383. runs 160-190. At idle in gear it can get up to 200-205ish if you sit long enough in the heat. It has a redone 22" radiator. How much would installing a shroud help???
Re: Cooling Question??? [Re: lukendan] #740638
07/05/10 02:09 AM
07/05/10 02:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
A ton! Get a shroud.
Re: Cooling Question??? [Re: autoxcuda] #740639
07/05/10 02:19 AM
07/05/10 02:19 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
should help a lot, it might still get to 200/205 but may take a lot longer
