trans brake not holding #740556
07/04/10 09:48 PM
07/04/10 09:48 PM
SE VA
hemibee69 Offline OP
SE VA
727, Griner low band apply transbrake will not hold the car at the starting line. The electric side is ok because I can back up with it. I went down the track after it rolled the beams and all 3 gears seemed OK, but above about 2000rpm the car rolls forward with the brake applied. I wish it was something easy, but high gear clutch pack or it's sealing rings seems like the likely culprit. What else to check before pulling the trans? Any easy checks or fixes other than remove and teardown?
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly)
1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph
1970 Challenger SE 383 4 bbl A/C PB PS Leather
1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
Re: trans brake not holding [Re: hemibee69] #740557
07/05/10 12:06 AM
07/05/10 12:06 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Start with the basics like adjusting the bands and if that doesn't help pull the VB and do an air check.
Post deleted by Defbob [Re: WILD BILL] #740558
07/05/10 12:36 AM
07/05/10 12:36 AM
Re: trans brake not holding #740559
07/05/10 12:50 AM
07/05/10 12:50 AM
Colorado
506RR Offline
506RR  Offline
Colorado
My Turbo Action Transbrake would always creep a little as well. Do yourself a favor and just tie it to the Line Lock. That is the way everyone I know does it.
Re: trans brake not holding [Re: 506RR] #740560
07/05/10 01:03 AM
07/05/10 01:03 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
We tie in the line lock as well. But like you said, Sounds like a high gear clutch/seal problem. Good luck!
Re: trans brake not holding [Re: 727builder] #740561
07/05/10 02:17 AM
07/05/10 02:17 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Rear band worn and out of adjustment.
Re: trans brake not holding [Re: hemibee69] #740562
07/05/10 02:20 AM
07/05/10 02:20 AM
NW Indiana USA
727specialist Offline
NW Indiana USA
It is not normal for a Griner brake to not hold.
A good brake should keep your car stopped without a line lock.
The first thing you need to do is adjust your rear band and check the line pressure.
The band needs to be adjusted on the tight side and the line pressure should be around 160 to 180 but not much higher than 180.
Re: trans brake not holding [Re: 506RR] #740563
07/05/10 08:25 AM
07/05/10 08:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Either your line pressure is low or you could increase
the revs before hitting the button... my TA brake
has never creeped(it been in there about 10 years)
Re: trans brake not holding [Re: MR_P_BODY] #740564
07/05/10 08:49 AM
07/05/10 08:49 AM
SE VA
SE VA
Thanks for all the replys, I do have it tied to the line-lock. The brake has always locked and held the car until this problem started.Air checking the high clutch pack with the valve body removed is something I did not think of. That will be the first thing to do after the valve body is out. I also had an early Turbo action transbrake before the Griner. The Engine RPM needed to be up for it to lock in as said earlier. The Griner is not like that.
Re: trans brake not holding [Re: hemibee69] #740565
07/05/10 09:47 AM
07/05/10 09:47 AM
oregon
savoyracer Offline
savoyracer  Offline
oregon
I would do some easy checks before removing anything. #1 place a ground strap from the trans to the frame , or battery, in order to eliminate a grounding problem. #2 increase engine RPM's when staging, to ensure adequate line pressure. #3 charge the battery, and then do a battery check, to be absolutely positive you have the voltage, just because you can back up, does NOT mean that you have adequate voltage to set the brake!!. and #4, if you are using synthetic fluid, take it out, replace with a good quality non- synthetic fluid. Only after these checks would I look internally.
Re: trans brake not holding [Re: 727specialist] #740566
07/05/10 10:26 AM
07/05/10 10:26 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I agree with 727 specialists if you have a lowband apply you don't need to tie it in with the line lock
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: trans brake not holding [Re: 65dragnet] #740567
07/05/10 11:39 AM
07/05/10 11:39 AM
AB
E
Efidart Offline
Efidart  Offline
E
AB
I had problems with my 727 creeping on the TB under boost with a t/a vb, I always activated the TB above 2000.
Went through the whole trans and couldnt find a problem, we upped the line pressure with no change at all. It never became a problem until I started putting it to higher rpm's with boost on the TB.
I cured the problem by going to a turbo 400, now the car is rock solid on the TB at any rpm/boost.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
