Re: carb issues
[Re: crazy_bee]
#740247
07/04/10 03:43 PM
07/04/10 03:43 PM
RapidRobert
It gets way too much fuel at idle and low speed
describe way too much fuel? Is the PV open? dripping fuel out the boosters? what idle speed? what initial? mixture screws having no effect? sight plug levels good? EDIT forgot the boosters, too much squirt? MORE EDIT what idle fuel psi?
Re: carb issues
[Re: crazy_bee]
#740249
07/05/10 11:15 AM
07/05/10 11:15 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
What you are smelling may not be from too rich. It is high hydracarbons (spelling) or unburned gas. It can be caused by several things. high compression, big cams with allot of overlap, timing not set right, even too lean. You may never get it to go away. Just make it some better. most motors that are built up from stock have this problem.
JAKES AUTOMOTIVE
