NE1 using a unilite in their 440 ? #74015
06/15/08 01:50 PM
06/15/08 01:50 PM
Spokane,WA
Genuinejed Offline OP
Spokane,WA
Just picked one up and was wondering if it's worth using. I have electronic with a chrome box now. Is there any advantage to the unilite? Also does anyone know how to hook it up? It has three wires coming out of it. I assume one is power and the other two are to the coil.
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
Re: NE1 using a unilite in their 440 ? [Re: Genuinejed] #74016
06/15/08 05:50 PM
06/15/08 05:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
not in a 440, but in a 383 and a 340. I like them till the module goes bad, (just like a fact ECM). IRC there is a red wire, goes to the + side of the coil. the other is a green wire that goes to the - side of the coil, and the brown wire goes to a good ground. Personally now days I prefer MSD products....
I am truckless..
Re: NE1 using a unilite in their 440 ? [Re: 340SHORTY] #74017
06/15/08 06:33 PM
06/15/08 06:33 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
I think the Unilite is JUNK only because the modules burn-up quite often. If you decide to use it buy the Mallory power filter #29351 it will prevent the module from failing.
