took mine for its maiden voyage last night #739851
07/04/10 07:51 AM
07/04/10 07:51 AM
ky
headhunter Offline OP
ky
went to a local cruise last night. first time out of the drive with her i just put the exhaust if you want to call it that on it yesterday. this thing is loud for a turbo car its a 4inch exhaust with a bullet muffler at the back tire. all i had room for it made it there and home im happy about that lol my wide band gauge must be wrong idleing its saying it lean i had 80 jets in the front you couldnt stay in the garage with it and the plugs were black. i went to a 74 jet it got to 200 by the time i got there it was 95 degrees here so that wasnt to bad i dont guess considering i dont have a intercooler to help cool the air going into the carb. i barely got on it two times 1st time i pulled out of my subdivision and shifted into second gear running 25 miles an hour rolled into the throttle a little it went to 3-4 pounds of boost and started spinning i lifted and scrared my wife to deaf with the blow off valve . then on the way home i was running 55 in drive and hit the gas and it started to spin agin lol still have a few gremlins to work out but it didnt scatter so it was a good night.
Re: took mine for its maiden voyage last night [Re: headhunter] #739852
07/04/10 08:07 AM
07/04/10 08:07 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
awsome!i am glad it did not foul the plugs so it would not run.that can be a read bummer.take your time working out the bugs.
Post deleted by Defbob [Re: blownzoom440] #739853
07/04/10 10:31 AM
07/04/10 10:31 AM
Re: took mine for its maiden voyage last night #739854
07/05/10 11:26 AM
07/05/10 11:26 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Sounds like the fun!
Where was the rod run? I was looking for somewhere to cruz the Challenger.
LJ has one next fri. But I will prolly be at US-60
Re: took mine for its maiden voyage last night [Re: FastmOp] #739855
07/06/10 06:17 AM
07/06/10 06:17 AM
ky
ky
sonic in etown first sat each month then bardstown and hillview the second sat hogenville the third as is value city on dixie in louisville the fourth is somerset you need to go to that one its huuuuuge theres a all day one in etown on july17th also ill be there
