Excessive blowby out of breather... #739571
07/03/10 06:14 PM
07/03/10 06:14 PM
Illinois
SGTFURY62 Offline OP
Illinois
Well I have the 360 running fairly well in the old truck (1976) but it has alot of blowby coming out of the passenger side valve cover breather. Nothing out of the drivers side pcv just all out of the passengers side. Is not smoking out of exhaust that I can see. Any ideas? I figured worn rings but exhaust is clear.
Re: Excessive blowby out of breather... [Re: SGTFURY62] #739572
07/03/10 07:10 PM
07/03/10 07:10 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Do you have a baffle in the valve cover?
Re: Excessive blowby out of breather... [Re: ireland383] #739573
07/03/10 07:12 PM
07/03/10 07:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Start with a compression check.
Re: Excessive blowby out of breather... [Re: SGTFURY62] #739574
07/03/10 07:20 PM
07/03/10 07:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Is the vacuum source to pcv adequate? And have you tried a new pcv valve?
Re: Excessive blowby out of breather... [Re: Alaskan_TA] #739575
07/03/10 07:22 PM
07/03/10 07:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Usually starts coming out of the breathers before the exhaust.
Might need valve seals or guides, in which case some smoke out of the tailpipes on deceleration might be noticed. Smoke on acceleration is typically poor ring seal. As noted, do a compression test and a leakdown test, and besides taking the readings, listen for air coming out of the carb (intake valve) or tailpipe (exhaust valve).
Re: Excessive blowby out of breather... [Re: buildanother] #739576
07/03/10 07:37 PM
07/03/10 07:37 PM
Illinois
Illinois
No, but going to go and get one asap. Also, will do a compression check as when I pulled pcv out of valve cover that side too was blowing smoke.
Re: Excessive blowby out of breather... [Re: buildanother] #739577
07/03/10 08:26 PM
07/03/10 08:26 PM
Az
Crizila Offline
Crizila  Offline
Az
Do first. Then comp test. Then pull a valve cover and look for pieces of valve stem seal laying down in the valve spring cup area.
Fastest 300
Re: Excessive blowby out of breather... [Re: Crizila] #739578
07/03/10 08:37 PM
07/03/10 08:37 PM
dulcich Offline
dulcich  Offline
1. Valve guides won't cause blowby.
2. PCV valve vacuum won't do anything but suck in the blowby.
3. Compression check really won't tell you much.
4. Valve seals won't cause blowby
5. You engine is plum wore out.
6. Schooling is now completed.
-dulcich
Re: Excessive blowby out of breather... [Re: dulcich] #739579
07/03/10 08:41 PM
07/03/10 08:41 PM
chicagoland,usa
chicagoland,usa
Point #2 Exactly. Because every engine has a little blowby.
Re: Excessive blowby out of breather... [Re: dulcich] #739580
07/04/10 12:10 AM
07/04/10 12:10 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
-dulcich
I just experianced the eventual fate of #5
I had noticed excessive blowby out of my breather in the Cuda about 6 month ago. Hot cranking would puff smoke before it even fired.
Motor had original 1968 pistons and bore. About 210,000 miles. I did a hone and bearing job in 1993 about 60,000 miles ago. A valve job about 30K mile ago.
Compression was good at 140 psi and even.
Motor was weak. Would not really tune right.
Then #6 rod bearing let go a couple weaks ago.
Motor was plum wore out.
Re: Excessive blowby out of breather... [Re: SGTFURY62] #739581
07/04/10 08:20 AM
07/04/10 08:20 AM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
I have seen the PCV hose blocked solid or collapsed internally and the passage in the carb blocked with crud. Make sure you have not only the correct vacuum reading at the valve but also lots of volume. Your engine should stall if you pull the PCV valve out of the hose. If you replace the hose don`t use fuel line as it will collapse in short order.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Excessive blowby out of breather... [Re: gamagoat6x6] #739582
07/04/10 01:02 PM
07/04/10 01:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Check first, but dulcich's #5 is probably correct. Just a good idea to verify you don't have another simple to fix problem before you start re-ringing, etc.
Fastest 300
