Tremec based 5 Speed swap...how much did it cost you ? #73908
06/15/08 03:46 AM
06/15/08 03:46 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
How much did your conversion to a 5 speed cost you ?
I have most of the stuff to go 4 speed, but I flogged a Keisler equipped car tonight and it was love at first shift. I desperately want OD now.
If I have the bellhousing, pedals, linkage and flywheel...how much will it run me to get a 5 speed into the car, and how all is offering kits aside from Keisler ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Tremec based 5 Speed swap...how much did it cost you ? [Re: AlexP] #73909
06/15/08 12:32 PM
06/15/08 12:32 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
The cost will vary depending on what you need. The 4 spd to 5 spd 'kit' prices assume several things. Some of these include that you send them your existing bellhousing to be remachined for the Tremec. If not then a new Kiesler unit is about $300. A pistol grip will run you about $140? if you don't already have one and a decent clutch and press plate will be another $300 or so. They will also make up a new driveline (incl in kit) but they require that you to first install the trans, measure the distance, and then fax them the info. Then about 2 weeks later you get your driveline. My 4 spd to 5 spd swap cost me $4,300 + or - but I upgraded the clutch, bought a new press plate and pistol grip and bought their bellhousing. I think the minimum you could get away for with the basic kit will be around $3,500 after shipping, etc.
Re: Tremec based 5 Speed swap...how much did it cost you ? [Re: Classof70Chally] #73910
06/15/08 12:43 PM
06/15/08 12:43 PM
the house on the left.
cogen80 Offline
cogen80  Offline
what about sending your 4 speed to passon for the OD treatment?
Re: Tremec based 5 Speed swap...how much did it cost you ? [Re: AlexP] #73911
06/15/08 01:33 PM
06/15/08 01:33 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
I did bought mine 2 years ago at the nats.I have about 4k into it.I had the factory bell and flywheel, but ended up with an after market billet flywheel. Cast flywheel and aluminum bell
scared me a little. I think I'll buy a Quicktime
bell shortly. But the car is a joy to drive.
Mike
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: mkdart] #73912
06/15/08 04:20 PM
06/15/08 04:20 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
What clutch do you have to use with their kits ? Isn't a mustang 26 spline clutch ?
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: AlexP] #73913
06/15/08 05:17 PM
06/15/08 05:17 PM
Omaha, NE
Danimal Offline
super gas
Danimal  Offline
super gas
Omaha, NE
i bought the mcleod street-twin clutch/pressure plate package from keisler several years ago when i was planning that same swap behind a 440.
it's got a 130 tooth/6-bolt flywheel and 26 spline clutch disks.
I'm trying to get rid of the clutch/pressure plate now since that project is long gone. so if you need one with only some shelf wear at a big discount let me know.
~Dan '67 Dart '98 Jeep Cherokee Classic
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: Danimal] #73914
06/15/08 08:44 PM
06/15/08 08:44 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
About 4 grand out-the-door about 5 years ago. Worth it.
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: AlexP] #73915
06/15/08 08:49 PM
06/15/08 08:49 PM
None
71rm23 Offline
71rm23  Offline
None
Wasn't there a post from someone who had problems with the Keisler units? I could be wrong I my self don't like the idea of having something else but a Mopar behind my motor. Yet, I too, want a OD. What to do?
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: AlexP] #73916
06/15/08 09:51 PM
06/15/08 09:51 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
A bit over $4,000.00
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: 5spdcuda] #73917
06/16/08 09:22 AM
06/16/08 09:22 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Under $3k
I think a B body would be much easier than my E-body swap.
Start with a Mustang spec TKO600 and get a Lakewood bell. Turn the TKO bearing retainer to Mopar size and re-fit. Mock it up, mark bolt holes in lakewood and drill. Bolt it together with flange nuts inside and tack weld nuts.
Use factory clutch linkage with a Jeep 4.0L throwout bearing with is a dead ringer for the mopar one but fits the Tremec bearing tube perfectly.
The TKO's use a Chevy spline and since GM and Mopar Pressure plates have the same pattern I was simply able to buy an off the shelf 11" clutch kit from Summit for an GM product.
Since the B-body shifter position is located forward more than the E-body you would have to relocate the shifter to one of the other positions. It will be on center rather than offset to the drivers side.
Theres more homework to be done but that the jist of it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: CJK440] #73918
06/16/08 11:08 AM
06/16/08 11:08 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I wonder if you have to cut the cross member on a b-body to get a tko to fit? Doesn't the new Quicktime bell allow you to bolt up a TKO? This might make it a little easier for the DIYer.
I have $3500 in my kit. The only extras were the disc ($69) and T/O bearing.
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: RTSE4ME] #73919
06/16/08 11:49 AM
06/16/08 11:49 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
If you look at the pics on Keislers site, they have the shifter in the middle position and the rearmost (mustang) position has been notched and a custom sheetmetal cover RTV'ed on which must be to clear the T-bar crossmember Arch. Probably the DIY could accomplish the same easily with access to a mill.
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: CJK440] #73920
06/16/08 03:13 PM
06/16/08 03:13 PM
dogdays Offline
dogdays  Offline
How about with access to a hacksaw and flat file?
R.
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: dogdays] #73921
06/16/08 03:17 PM
06/16/08 03:17 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Sure, why not. Hey, I took a sawzall and chopped out the center of the T-bar X-member on my 71 cuda to fit my Tremec.
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: CJK440] #73922
06/16/08 04:58 PM
06/16/08 04:58 PM
Tennessee
rj8806 Offline
rj8806  Offline
Tennessee
O.k., the mustang "spec" TKO is not correct. All TKO's are based on a Ford transmission(not the mustang). The only mustang that a TKO fits in directly is a Fox body car (1979-1993).
If you have a 4 speed car, the price is generally in the $3200-$3500 range depending on what you need.
On a 4 speed car, the torsion bar cross member is in the way of our shifter, therefore, we have to move the shifter over to the center of the tunnel. Because the carpet has a hole in it for the 4 speed offset towards the drivers side, you'll need to switch over to the automatic carpet. Other than cutting a 3 1/2" x 2 1/2" hole for the new shifter location, there is no more cutting involved on a B-body 4 speed swap over.
Richard
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: rj8806] #73923
06/16/08 05:07 PM
06/16/08 05:07 PM
Richmond, TX
Sinister68 Offline
Sinister68  Offline
Richmond, TX
>$5K for the whole conversion kit from Automatic to TKO500
-James 2013 Challenger SRT 1968 Charger R/T
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: Sinister68] #73924
06/16/08 05:09 PM
06/16/08 05:09 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Is this the 68 Charger that Alex got a ride in?
Darren
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: Sinister68] #73925
06/16/08 05:16 PM
06/16/08 05:16 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I spoke with Gene today breifly. He said I can be done for about what I was thinking. I can use my lakewood bellhousing and a lot of the stuff I have gathered. After experiencing OD in a hotrod, I don't think I would live with a 1:1 top gear...
What is the consensus on using an 11" aluminum flywheel on a street car that will be used daily ? I picked up on the Mcleod sale for $217 to my door on a 143T flywheel, and I would really like to use it....
Re: Tremec based 5 Speed swap...how much did it cost yo [Re: Ludington1] #73926
06/16/08 05:20 PM
06/16/08 05:20 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Nope, it was another Houston buddy of mine. He tried every hydraulic throw out bearing under the sun, and now has a very poorly functioning mechaincal linkage in the car, but it works...barely. I will stay with a mechanical linkage for my car.
Re: Tremec based 5 Speed swap...how much did it cost you ? [Re: AlexP] #73927
06/16/08 06:06 PM
06/16/08 06:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here are some pics of the install. The dreaded hole. [lol].
