Carb spacer #739035
07/02/10 09:54 PM
07/02/10 09:54 PM
tennessee
P
pushbutton Offline OP
P
tennessee
Where can you get a 4 hole 1/2" square bore wood spacer?
Re: Carb spacer [Re: pushbutton] #739036
07/03/10 12:05 AM
07/03/10 12:05 AM
Iowa
3
318Bruiser Offline
318Bruiser  Offline
Iowa
Make one, they are easy to do. Just make sure you measure twice and cut once. Google it and it will tell you what type of wood or even what measurements to use.
Re: Carb spacer [Re: 318Bruiser] #739037
07/03/10 06:48 AM
07/03/10 06:48 AM
tennessee
P
P
tennessee
Might have to do that. Could use carb base gasket as a templet.
Re: Carb spacer [Re: pushbutton] #739038
07/03/10 07:32 AM
07/03/10 07:32 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Re: Carb spacer [Re: TooMany62s] #739039
07/03/10 01:20 PM
07/03/10 01:20 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Why wood instead of phenolic? Just curious.
EDIT: Oh sorry didn't see the 1/2" part... makes more sense now
Re: Carb spacer [Re: Alikazam] #739040
07/03/10 02:55 PM
07/03/10 02:55 PM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
Re: Carb spacer [Re: TooMany62s] #739041
07/03/10 03:03 PM
07/03/10 03:03 PM
tennessee
P
P
tennessee
Here: http://www.jegs.com/i/Edelbrock/350/8723/10002/-1
That's it! Wouldn't you know I just ordered from Jegs a few wk's back.
Re: Carb spacer [Re: 1BAD68] #739042
07/03/10 10:54 PM
07/03/10 10:54 PM
tennessee
P
P
tennessee
Here's a link to some good info on spacers...
http://www.gnetworks.com/v4files/barrygrant/Spacers%20with%20images.pdf
Interesting read,thanks. Trying to improve a hot start problem with the problem prone eddy 750. Didn't think about the wood soaking up fuel.
