Iron or aluminum case a833 4 speed, whats better?
#738994
07/02/10 08:40 PM
07/02/10 08:40 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
Hello, Right now I have an aluminum cased A833 overdrive in my 72 Duster with a 318 and 3:91 sure grip 8 3/4. I'm going to look at a 360/4 speed setup that was in a 71 Dart and is soposed to have an iron case A833, dont know if its OD or not. My current trans workes perfectly but this one is also soposed to be in good shape.
Whats the better unit to use, the aluminum or the iron? I'm looking at building up the 360 to around 400HP (crank), I figure the aluminum must be alot lighter but would the iron unit be stronger? Need some sugestions. I'll know more when I take a look at it but I'm 98% sure I'm getting it in any case, figure I'll just sell whichever trans I dont use.
Any opinions?
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Iron or aluminum case a833 4 speed, whats better?
[Re: 440Satellite]
#738995
07/02/10 09:00 PM
07/02/10 09:00 PM
Posts: 12,235 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We've used the al. 833 ODs a lot, even behind big blocks. They do okay. But they will not take a pounding. If you plan to beat on the thing, don't go with the aluminum case.
Master, again and still
[Re: DaveRS23]
#738997
07/03/10 12:13 AM
07/03/10 12:13 AM
DaytonaTurbo
Manitoba, Canada
The issue with the aluminum case is the trans shafts float in the aluminum case. What this means is there's a hole in the trans case and the tip of the shaft rides in this hole. What happens over time is that hole gets worn open because the aluminum is too soft. Eventually this results in poor gear meshing giving you a crappy shift and eventual transmission death. The iron case is the better case, unless you have bushings installed into the aluminum case to solve the problem, but it is a precision operation to install the bushings.
As for the strength of the guts, it's said the overdrive gear in the OD833's is weak and not suited for WOT action, just cruising, but the 1-3 gears are not any weaker than the 1-4 gears in any other 23spline 833 with the 3.09 1st gear.
[Re: DaytonaTurbo]
#738998
07/04/10 11:38 AM
07/04/10 11:38 AM
440Satellite
super gas
super gas
Hazlet, NJ
Thanks for all the info guys. Maybe I'll just keep both, use the od for now and if it dies swap out to the iron.
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#738999
07/13/10 05:14 PM
07/13/10 05:14 PM
440Satellite
super gas
super gas
Hazlet, NJ
I picked up the motor and tranny, its an iron case trans with thes numbers...
C-99386 on the cover C-99129 on the side of the case C-99126-1 on the tail shaft
Can anyone id this trans, it also apears to have a 4 3/8" bearing retainer. Any idea if its OD or not, if not what kind of gears did these have?
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#739001
07/13/10 06:14 PM
07/13/10 06:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Stock, the OD trans only had a 5.125" retainer.
[Re: 440Satellite]
#739002
07/13/10 08:51 PM
07/13/10 08:51 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Butch
castings numbers 9.9 times out of 10 are absolutely useless to identify an 833 , this case falls in the 9.9 times .
That is not an OD retainer, it's the smallblock sized retainer so it's more than likely NOT an OD trans , what is the info STAMPED on the little ID pad ? That will help more to identify the trans .
[Re: JohnRR]
#739003
07/14/10 09:21 PM
07/14/10 09:21 PM
440Satellite
super gas
super gas
Hazlet, NJ
Ok the best I can tell the numbers on the ID pad are as follows...
4B297511 PP83 4575
Does that help any? So it looks like its a non OD tranny which sounds like its good if I build a motor with some serious power, but maybe better off with the OD for a 400-under 360 street motor with 3.91's
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#739004
07/14/10 10:17 PM
07/14/10 10:17 PM
Posts: 704 USA
rftroy
USA
Looks like a 1974 transmission. This is the close ratio unit made from 71 to 74. Best for winding road driving. If you don't want it ........ Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#739005
07/15/10 05:09 PM
07/15/10 05:09 PM
440Satellite
super gas
super gas
Hazlet, NJ
Looks like you have a few 4 speed cars!!! What is the first # the year? So would this tranny be better for street perfomance than the OD? Dont really get over 60MPH much, just cruising around town, like to get from 0-60 as fast as posible . Butch
1972 Duster
318 4 speed
