Correct Gounding For Engine w/Alum. Heads #738435
07/02/10 07:49 AM
07/02/10 07:49 AM
Eau Claire, WI
ResQ911 Offline OP
super gas
ResQ911  Offline OP
super gas
Eau Claire, WI
I am worried about electrolosis wrecking my new aluminum heads. I saw a post awhile back that had pics of some pretty bad pitting on head faces. I don't want this to happen to me. Been told to change coolant regularly and have good grounds. I have a ground from battery to block and from one head to firewall.
Problems? Suggestions?
I already added an anode into an unused waterpump port for insurance.
Is this enough?
Thanks!!!
Re: Correct Gounding For Engine w/Alum. Heads [Re: ResQ911] #738436
07/02/10 11:07 AM
07/02/10 11:07 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ground to block is fine.
Coolant ("antifreeze") and/or Water Wetter will handle the aluminum, especially since you're using an anode. The anode will need to be replaced from time to time.
Sounds to me like you're on top of it.
Re: Correct Gounding For Engine w/Alum. Heads [Re: topside] #738437
07/02/10 12:46 PM
07/02/10 12:46 PM
Eau Claire, WI
ResQ911 Offline OP
super gas
ResQ911  Offline OP
super gas
Eau Claire, WI
So by the lack of replies, I am guessing I am worrying about this for nothing.....................?
