Re: cooling fan
[Re: j3wbagell]
#738097
07/01/10 03:56 PM
07/01/10 03:56 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Are you having a cooling problem?
If that car has A/C it should have had a 20" or 21" 7 blade clutch fan from the factory. What kind of cooling system is in the car? Radiator, fan, shroud, etc.
Re: cooling fan
[Re: j3wbagell]
#738099
07/01/10 04:54 PM
07/01/10 04:54 PM
Posts: 512 Sacramento, CA
Bdrainy
Sacramento, CA
There is no fan system in the car at the current moment nor when i took her around the block. I only have a 28" radiator that i have no id on the functionality of.
You don't have a fan on there at all? If you are just idling and driving around the block without a fan, that's why you are over heating. You're not getting any air flow through the radiator.
I have used the parts store nylon/plastic fans with a universal spacer before with decent results.
Sorry, maybe I misunderstood the post, but it seems like you are not running a fan...?
Re: cooling fan
[Re: Bdrainy]
#738100
07/01/10 05:27 PM
07/01/10 05:27 PM
feets
Senior Management
Senior Management
Irving, TX
That's how it sounds to me too.
Cars with A/C got different cooling fans and sometimes different radiators too. I don't care if yours works. The question was to find out if you had the upgraded cooling system.
Is there any fan on the car? Electric or mechanical?
Re: cooling fan
[Re: feets]
#738101
07/01/10 07:20 PM
07/01/10 07:20 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
I'm really tired of this kind of stuff on this forum it quite clearly says there is no fan and that i am looking to buy one.
Can someone please recommend where i can find a clutch and fan for cheap? vicious or not
Re: cooling fan
[Re: j3wbagell]
#738103
07/01/10 07:59 PM
07/01/10 07:59 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Holy cow dude. Lose the attitude.
Get a fan and whatever from any auto parts store or your local speed shop. What do you mean by cheap? Ya get what you pay for.
