440 RB - Oil Concern During Engine Prime #737832
07/01/10 07:30 AM
07/01/10 07:30 AM
Detroit, MI
kz5rt2 Offline OP
kz5rt2  Offline OP
Detroit, MI
I just completed my first 440 build with the help of a Buick Big Block engine builder.
During engine priming he noticed you had to rotate the crank to get any oiling. When the oil started to flow, it was like a waterfall out of the rocker shaft which really seemed excessive!
Is this common? Should I have used oil restrictors? I have a high volume oil pump, same one most people use on ~450-500hp engine build.
Re: 440 RB - Oil Concern During Engine Prime [Re: kz5rt2] #737833
07/01/10 07:54 AM
07/01/10 07:54 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yes it's common. The facotry oiling for the heads is timed off the # 4 cam bearing. They don't get constant oiling so to prime everything properly you need to ratate the engine.
Re: 440 RB - Oil Concern During Engine Prime [Re: WILD BILL] #737834
07/01/10 10:07 AM
07/01/10 10:07 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
x2
Re: 440 RB - Oil Concern During Engine Prime [Re: kz5rt2] #737835
07/01/10 06:20 PM
07/01/10 06:20 PM
NL
Frederick Offline
Frederick  Offline
NL
Not out of the ends I hope?
Otherwise check the end plugs.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
