Re: Car Eating Alternators....
[Re: BAM]
#737664
06/30/10 10:30 PM
06/30/10 10:30 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I rebuild my own alternators and have for 30 years for that very reason. The rebuilds at the chain stores have always been poor. They have one moving part, 4 wear items yet they all seem to be a pain for rebuilding companies to figure out. Nothing in your list of items draw a lot of current. I bet there is nothing wrong, just a run of bad alternators.
Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: BAM]
#737667
07/01/10 02:24 PM
07/01/10 02:24 PM
Posts: 12,416 Taxes & Virus's R-US, NY
Dragula
Folks,
66 Satellite with 68 440 Fury engine, MSD ignition with MSD distributor....third unit has died since October....2 were Napa, one was Autozone supplied...tension good, no squealing....coming back from 150 mile trip Sunday, dang thing dies with 30 miles to go....
Any ideas of the cause?????
Thanks, BAMMER
Typically the Chrysler alternators will not handle high loads over time well and most of all, they hate high rpm blasts thru the gears. The windings always come loose and they make a mess from there.
Best thing you can do is convert over to the newer style from Mancini. Burn outs and hole-shots killed more than a few of mine on the street, and at the track, if the belt stayed on, the pulley would blow right off.
Its one of the few parts on a Chrysler that are complete junk. Sorry, but I have switched both cars over to after market set-ups and even bought a spare for the Hemi, and after 7 yrs, I still haven't used it. One has a Mancini set-up and the other is custom set-up with a cheppy alternator.
[Re: BAM]
#737668
07/01/10 07:53 PM
07/01/10 07:53 PM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
I'm having the same problem with my 69 Satellite bracket car. I go through an alternator each year. Just last August now this past weekend. On my car its shorting out & draining the battery between rounds. I talked with the guy at the parts store I mostly deal with & he said in discust that the problem is Chinese rebuilds. He says they are junk. He pulled two from the shelf to test & both where bad. One had a broken terminal stud on the back. I too thought about updating to the newer style alternator. However I have read on here that the wiring needs to be updated to handle the amprage. So I guesss I will just have to carry a new spare with me.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
[Re: rockerbob]
#737670
07/01/10 08:33 PM
07/01/10 08:33 PM
Posts: 2,826 NY usa
540challenger
NY usa
I think you hit the nail on the head with this post. Given the age of the mopar alternators, lack of quality parts, and lack of quality rebuilders out there. i brought my Alternator to a local rebuilder who bee in the business for a long time. And discussed the issues wth almost all rebuild and i had them rebuild my alternator it cost around 250.00 and i have had zero problems since and my alternator been through hell from my 408.
[Re: BAM]
#737677
07/04/10 07:08 PM
07/04/10 07:08 PM
rockerbob
Raleigh, NC
Saturday I went looking for a replacement alternator. I went to the parts store with the bad alt. & reciept in hand. They checked it & it was bad. Didn't have an other. Called a nearby sister store & they had one. Drove over. Had them check the new one & it was bad. They called another sister store. They had one & checked it before I drove over. It was good. So for now my car is working again. Think I will buy a spare so I can fix it at the track if need be.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
[Re: ahy]
#737679
07/05/10 09:04 AM
07/05/10 09:04 AM
Posts: 366 San Gabriel, CA 91775
rexus31
I recently had a similar issue with my freshly restored '65 300 'vert. The Alternator would not charge. I went through 3 alternators as the tester at O'Reilly's was not working. When the third wouldn't charge I took it to Autozone for a test assuming I would have to get my money back from O'Reilly's and purchase a new one from Autozone. They put it on the tester and it passed. I then changed the VR with a known working unit, no dice. I checked all the voltages with the key in the On position and the ignition wire disconnected from the Ballast and all the voltages were within spec. I was at a loss. I disconnected the Field wire at the Alternator and VR and attached a wire to the two external from the harness. I fired it up and the Alternator charged. Long story short, my brand new Bill Evans Engine Harness had a poor connection at the Alternator side of the Field wire. After removing the black plastic shield, I saw the connector was primarily crimped to the wire jacked and wasn't making a good connection with the bare wire. I installed a new connector and all is good. Don't discount the harness.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
