Valve cover breather grommet #737221
06/30/10 08:11 AM
06/30/10 08:11 AM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
One of the grommets is tore on my cast aluminum Mopar valve covers. It's for my evac breather, and I can't find one at the parts store and I don't see one in Jegs or Summit. Any ideas on where to get a couple? Thanks, Clint
Re: Valve cover breather grommet [Re: 80arrow] #737222
06/30/10 09:17 AM
06/30/10 09:17 AM
PA USA
flatiron Offline
flatiron  Offline
PA USA
Try KMJ Performance, When I bought my valve covers they had them. Are they a oddball size?
Re: Valve cover breather grommet [Re: 80arrow] #737223
06/30/10 10:10 AM
06/30/10 10:10 AM
DES MOINES IOWA
P
PARTSMAN440 Offline
PARTSMAN440  Offline
P
DES MOINES IOWA
Some of the grommets used are plain old mother mopar, and have part numbers. Look on your old grommet and look for numbers. If not call me here at the dealship 877-370-2901 ask for Tim. I bet I can help you find one at you local dealership.
Re: Valve cover breather grommet [Re: 80arrow] #737224
06/30/10 10:33 AM
06/30/10 10:33 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The normal MP breather grommet for that is P5007921.
Personally I like the OEM Mopar grommets a little better, which is (no P) 2946079. The only problem with the OE grommet is, it doesn't fit the hole in the valve cover very well....the hole needs to be opened up slightly. That, and the grommet has to be stretched a bit to go into the cast cover. But once they're in they aren't going to tear, leak, or move around for many years.
Rich H.
Esse Quam Videri
Re: Valve cover breather grommet [Re: 80arrow] #737225
06/30/10 03:13 PM
06/30/10 03:13 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Go on Summits website an type in VALVE COVER GROMMETS. There are several listed.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
