A/C ? #736607
06/29/10 04:13 PM
06/29/10 04:13 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
When the eng is cold the a/c blows cold but once the eng warms up it blows hot. I checked the heater core bypass door actuator and it works. My question is could the water temp control valve be the culprit?
Re: A/C ? [Re: 73 SSP] #736608
06/29/10 04:19 PM
06/29/10 04:19 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Yes. It could. Be sure the temp control move the valve shut off lever if it has one.
Re: A/C ? [Re: 73 SSP] #736609
06/29/10 04:20 PM
06/29/10 04:20 PM
Az
Crizila Offline
Crizila  Offline
Az
Pinch off the heater core hose and see if that makes a difference. Also, if the AC is working all the time, the tail pipe ( by the expansion valve ) will be cold all the time.
Fastest 300
Re: A/C ? [Re: Crizila] #736610
06/29/10 04:48 PM
06/29/10 04:48 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Thanks Crizila that did the trick. I guess I need to find a new contol valve as this one seems to be faulty.
