440 auto to 4 speed.............
#73620
06/14/08 04:26 PM
06/14/08 04:26 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i got a good 440 out of a 75 new yorker and put it in our 71 charger and bought most all the parts to convert to a 4 speed it was pointed out that i could not put a 4 speed behind a 440 that had a cast crank because of balancing i bought a 11 inch flywheel but was told cant use it behind the cast crank 440 am i screwed here now??
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: 440 auto to 4 speed.............
[Re: DaytonaTurbo]
#73624
06/16/08 10:22 AM
06/16/08 10:22 AM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
What is this one from? Cast Crank? What engine? Ignore what some junkyard dog wrote on it.
[Re: GomangoCuda]
#73625
06/16/08 10:59 AM
06/16/08 10:59 AM
Posts: 4,285 Ohio
64dodge572
Ohio
70-2 10.5" 440 with heavy rods (6-pack)
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: R/T1968R/T]
#73627
06/16/08 11:59 AM
06/16/08 11:59 AM
DaytonaTurbo
Manitoba, Canada
I dont think you have a pilot pushing in a cast crank or a deep enough hole to install one. Check and make sure!!
They make one specifically for use in an auto trans crank. It's shaped a little different and sits in the hole for the torq converter snout. Only mod you have to do is trimming the tip of the input shaft a little shorter.
[Re: DaytonaTurbo]
#73628
06/16/08 12:37 PM
06/16/08 12:37 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
that is what i had planed on doing was get the bushing that fits into the converter hole the flywheel i have is a 11 inch and the motor is a cast crank 75 440 where can i buy a templet to drill the flywheel to make it work?
