stealth heads? #736116
06/28/10 10:35 PM
06/28/10 10:35 PM
kenner louisiana
73_dart_beast Offline OP
kenner louisiana
I want to build a 512 stroaker and i was concidering using the cnc ported stealth heads from 440source. Anyway do any of you have thease heads? If so what type of power are they capeable of making? Can the heads handle being cnc ported to the maxwedge size ports and would they flow more than the standard cnc port? Thanks in advance, have a great day...
Re: stealth heads? [Re: 73_dart_beast] #736117
06/28/10 10:44 PM
06/28/10 10:44 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
i built a mild 528 six pack for a customer, and used a set of stealth heads. they were'nt ported but they handle it very well. all in all they work pretty good for what they are. i don't know if i would use them on an all out race motor,
Re: stealth heads? [Re: 73_dart_beast] #736118
06/29/10 12:04 AM
06/29/10 12:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I want to build a 512 stroaker and i was concidering using the cnc ported stealth heads from 440source. Anyway do any of you have thease heads? If so what type of power are they capable of making? Can the heads handle being cnc ported to the maxwedge size ports and would they flow more than the standard cnc port? Thanks in advance, have a great day...
The 440 source Stealth and Edelbrock RPM heads really are geared / sold as aluminum replacement heads that make good power, but I would not bother trying to make them into a race head. If you want a max wedge port size head, use the Indy, Edelbrock Victor M/W, B1, or (I think pro-comp may have a M/W port size head?)
Re: stealth heads? [Re: 451Mopar] #736119
06/29/10 10:10 AM
06/29/10 10:10 AM
kenner louisiana
kenner louisiana
Thanks for the info. I am really looking to make a 700 HP street srtip car. To hurt some feelings here in the big easy.
Re: stealth heads? [Re: 73_dart_beast] #736120
06/29/10 10:30 AM
06/29/10 10:30 AM
AndyF Offline
AndyF  Offline
The CNC version should support 700 hp on a 512 inch shortblock. You'll need plenty of compression, cam and intake. Wouldn't be all that street friendly but you can make 700 hp with that combo.
Re: stealth heads? [Re: 73_dart_beast] #736121
06/29/10 10:46 AM
06/29/10 10:46 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Hurt some feelings , I like that. I agree, if 700hp is the number you need, and you like the Stealth value, I might look to the Pro Comp Victor copies. They are selling those for like 1500 bucks cnc ported. The Stealths could get you to 700, but would need to be a max effort type build.
2 kids and a dog
Re: stealth heads? [Re: TonyS451] #736122
06/29/10 11:50 AM
06/29/10 11:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree the Stealths are a good buy for what they are.My motor is pushing 600 with them and they have been on 3 years street strip.Ive heard some of the other heads suggested are cracking and porous.If you want to go Max wedge Id look at Indys.Rocky
Chrysler Firepower
Re: stealth heads? [Re: 73_dart_beast] #736123
06/29/10 11:53 AM
06/29/10 11:53 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
There is a guy on the Big Block Dart site who took his Stealth heads up to MW port size. I believe he needed to do a bit of TIG welding, but he definitely did it. If I'm not mistaken he's running 8s in an Arrow.
Re: stealth heads? [Re: PolyDart] #736124
06/29/10 05:08 PM
06/29/10 05:08 PM
kenner louisiana
kenner louisiana
Thanks for the tips...
Re: stealth heads? [Re: TonyS451] #736125
06/29/10 07:17 PM
06/29/10 07:17 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
the motor would be pretty hairy..not much fun on the street. 700 HP is alot for any street motor..unless forced induction or nitrous is used. Something like a 572 with SR heads is what it would take to get 700 "streetable" N/A horsepower...and thats big $$$.
Re: stealth heads? [Re: B1Fish540] #736126
06/29/10 11:52 PM
06/29/10 11:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
700 HP is a blast on the street, but way too easy to get a ticket
Here is a MaxWedge intake gasket on a stealth head to get an idea of the port size difference.
Re: stealth heads? [Re: 451Mopar] #736127
06/30/10 12:01 AM
06/30/10 12:01 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Victor MW vs. Stealth intakes picture
Re: stealth heads? [Re: 451Mopar] #736128
06/30/10 12:02 AM
06/30/10 12:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Victor vs. stealth exhaust port picture
Re: stealth heads? [Re: 451Mopar] #736129
06/30/10 04:57 PM
06/30/10 04:57 PM
kenner louisiana
kenner louisiana
Thanks for all the help....
Re: stealth heads? [Re: TonyS451] #736130
06/30/10 05:03 PM
06/30/10 05:03 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
I agree this is a post here on my engine, similiar #'s https://board.moparts.org/ubbthreads/show...&PHPSESSID=
700hp just doesn't fall out of trees. Stealth heads are not going to get you there.
Re: stealth heads? [Re: 512 VALIANT] #736131
06/30/10 05:20 PM
06/30/10 05:20 PM
Utah
topbrent Offline
topbrent  Offline
Utah
If you can be satisfied with "only" 654-HP, build a clone of this engine.
It uses hand ported RPM heads. MCH cnc Stealth heads are even better.
There are many combinations out there, but this one is very impressive from the parts/cost/performance standpoint.
The Scott Brown built, 496 in Caper's car is simple and stout.
10.44 , 1.44 60 ft 3704lbs, street driven 654 hp , 653 ft tq
http://www.buyracingparts.com/dyno-ehead496.html
496 CID Wedge - pump gas street engine (10.7 to 1)
Straightline rotating assembly
Ported Edelbrock heads (300 CFM)
Ported Victor Single Plane
Straightline Flat tappet, 263/273 @ .050
4150 Carb ( Quick Fuel 1050-AN)
Indy Roller rockers
1" tapered spacer
383man [Re: topbrent] #736132
06/30/10 08:52 PM
06/30/10 08:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Indy Roller rockers
1" tapered spacer
Thats very close to what I want to build for my 63. When I can afford the parts I plan to build it as I want it to be a 3700 lb mid 10 second pump gas street car. Thats my ultimate goal with my 63 and I was planning on using Eddy heads and the Victor intake at first. Ron
Re: stealth heads? [Re: 512 VALIANT] #736133
06/30/10 11:35 PM
06/30/10 11:35 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
We have had quite a few people break the 700 HP mark with the CNC stealth heads done by Jeff at Modern. The heads are 320+ CFM, using the standard formula which translates CFM into horsepower potential (because internal combustion engines are, after all, large air pumps) 320 CFM comes out to about 690 horsepower or so, IIRC.
Re: stealth heads? [Re: 440sourcedotcom] #736134
07/01/10 12:51 AM
07/01/10 12:51 AM
AndyF Offline
AndyF  Offline
I agree, 700 certainly isn't impossible with the CNC ported Stealths. Might not be easy to do but shouldn't really be a problem for an experienced engine builder. Might not be the most cost effective way to make 700 hp but that is another matter.
Re: stealth heads? [Re: AndyF] #736135
07/01/10 07:49 AM
07/01/10 07:49 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
First off, let me say welcome to the board
While I've never run the Stealth heads, I've heard that they can be made to flow about the same as Eddy RPM's. If that's true, Like Adny said an experienced builder should be able to get you there.
We did make a couple of pulls on my Koffel's Place built 446 with hand ported eddy heads on C 12 .
The best Gas pull of the first go around. This was with the 5555 solid cam intaslled on a 108 CL
After the bearing and spring failure, Scott decided to adv the cam to 105 to make a little more piston to valve clearence and lower the RPM range to help my springs live longer and not float the valves.
All things being equal, I'ld think the extra cubes and maybe a bigger cam than I'm running would improve those numbers.
Assuming I'm not at the limit of what the heads can feed that is
