Line Lock/Porportioning valve #735989
06/28/10 08:23 PM
06/28/10 08:23 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Moparts, I need help identifying what this part is attached the master cylinder. It looks like a porporting/line lock combo maybe. It has to solenoids with three wires on it. What is this part and what does it do.
Re: Line Lock/Porportioning valve [Re: FIREGUY12] #735990
06/28/10 08:27 PM
06/28/10 08:27 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I see nothing
SRT DEMON ONE SEAT
Re: Line Lock/Porportioning valve [Re: FIREGUY12] #735991
06/28/10 08:28 PM
06/28/10 08:28 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
here is a picture
: Line Lock/Porportioning valve [Re: FIREGUY12] #735992
06/28/10 08:31 PM
06/28/10 08:31 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
Re: : Line Lock/Porportioning valve [Re: FIREGUY12] #735993
06/28/10 10:22 PM
06/28/10 10:22 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
Anyone have any info.PLEASE.
Re: : Line Lock/Porportioning valve [Re: FIREGUY12] #735994
06/29/10 08:38 AM
06/29/10 08:38 AM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
It may just be a line loc. I dont think its a prop valve.
Re: : Line Lock/Porportioning valve [Re: The Avg. Valiant] #735995
06/29/10 10:12 AM
06/29/10 10:12 AM
Az
Crizila Offline
Crizila  Offline
Az
Where are the wires going? It's not a prop valve. Is there an extra button or switch in the car that energizes the solinoids? Not a lot of info from he pic, but it doesn't look OEM installed from the lines I can see.
Fastest 300
Re: : Line Lock/Porportioning valve [Re: Crizila] #735996
06/29/10 04:09 PM
06/29/10 04:09 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
there are four wires black,green,white,blue.The only one that was connected was the black going to ground the remainder of the wires are cut. One of the brake lines off the master cylinder goes in and comes out the other side.
Re: : Line Lock/Porportioning valve [Re: FIREGUY12] #735997
06/30/10 10:24 PM
06/30/10 10:24 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Some type of sender for electric trailer brakes ?
Re: : Line Lock/Porportioning valve [Re: tubtar] #735998
06/30/10 10:26 PM
06/30/10 10:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He posted this in the tech section also and got his answer , it's some kind of rear wheel anti lock device that someone turned into a line lock .
Re: : Line Lock/Porportioning valve [Re: JohnRR] #735999
06/30/10 11:01 PM
06/30/10 11:01 PM
Az
Crizila Offline
Crizila  Offline
Az
That was going to be my guess. Anti-lock from the mid/ late 80's.
Fastest 300
Re: : Line Lock/Porportioning valve [Re: Crizila] #736000
07/02/10 12:29 PM
07/02/10 12:29 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
Thanks moparts
