rockers and shafts #735965
06/28/10 08:20 PM
06/28/10 08:20 PM
Fredericton NB Canada
471b1dart Offline OP
need to buy a new set of rockers for my b1bs heads , I am leaning towards T&D or Harland sharp which do you guys prefer ???
Re: rockers and shafts [Re: 471b1dart] #735966
06/28/10 08:23 PM
06/28/10 08:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m likin my Harlands..........5+ years street/strip and they`re still kickin.
Re: rockers and shafts [Re: Thumperdart] #735967
06/28/10 09:45 PM
06/28/10 09:45 PM
ky
68roadrunner Offline
ky
i just put h.s. on my indy -1 setup, if i had of hed the time to wait i would have gotten t&d. if you shop around you can get as good of price on them, you just have to wait 2-3 weeks.
Re: rockers and shafts [Re: 68roadrunner] #735968
06/28/10 09:54 PM
06/28/10 09:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I called Nick at Compuflo a couple of weeks ago for a set of 1.6 T&D'S for my 440-1 Indy's. They didn't have any on stock so they made a set and had them sitting on my porch in one week. Nick said it would probably be 7-10 days. Great price too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: rockers and shafts [Re: Thumperdart] #735969
06/28/10 10:36 PM
06/28/10 10:36 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thump. What heads u running?have u always run the Harland sharps? Trying to find out if any advantage to running a set of the Harland,T&D's rockers?Any gains in et./mph Thaxx. P.S I run the rockers that come in the 440-1 kit and i'm in the need 4 a set of rockers.
Re: rockers and shafts [Re: racerx] #735970
06/29/10 12:44 AM
06/29/10 12:44 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m running rpm`s home ported by me and I`ve used em from day one w/these heads and that`s 5+ years. Good stuff.....no experience w/t&d stuff although I`ve heard great things.
Re: rockers and shafts [Re: 471b1dart] #735971
06/29/10 01:30 AM
06/29/10 01:30 AM
What kind of spring pressures and RPM do you intend to run? I have both brands on different motors, two sets of Harland Sharps on Eddy RPM heads and one set of single shaft T&Ds on a set of Indy SR heads. Caution, the HS ratio are not as advertised, my 1.6 ratio check out at the retainers to be 1.64 and the 1.5 HS check out to be 1.54. My T&Ds on the SR heads where suppose to be 1.65 ratio and they are close, not dead nuts on all sixteen but close
Re: rockers and shafts [Re: Cab_Burge] #735972
06/29/10 09:30 AM
06/29/10 09:30 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Been running T&D for 9 years on B1BS headed S/G with no problems.
Re: rockers and shafts [Re: Cab_Burge] #735973
06/29/10 09:01 PM
06/29/10 09:01 PM
Cab , my pressures are 21o# closed and 605# open and the engine sees about 7800rpm , cam card says good to 8000, valve float about 8500.
