Re: 1968 Road Runner undercarriage color [Re: 68RRFlyer] #73557
06/15/08 01:25 PM
06/15/08 01:25 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Amazing how an unchallenged lie can become the absolute truth.
Re: 1968 Road Runner undercarriage color [Re: 68RRFlyer] #73558
06/15/08 01:46 PM
06/15/08 01:46 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
A typical Chrysler spray booth.
Re: 1968 Road Runner undercarriage color [Re: beepbeep] #73559
06/15/08 02:14 PM
06/15/08 02:14 PM
DFW
68RRFlyer Offline OP
DFW
Fantastic guys. Thanks mopar for the emailed pics. And Thanks beepbeep for the rest of the pics and reference material. My car was repainted so I can't see the original blackout area so I'll have to go by examples. My color is LL1 so I'll need it.
Cheers
Re: 1968 Road Runner undercarriage color [Re: 68RRFlyer] #73560
06/15/08 06:37 PM
06/15/08 06:37 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Left side radiator paint, unmolested 69RR.
Re: 1968 Road Runner undercarriage color [Re: 474218] #73561
06/15/08 06:38 PM
06/15/08 06:38 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Right side radiator paint, unmolested 69RR.
Re: 1968 Road Runner undercarriage color [Re: 474218] #73562
06/15/08 07:28 PM
06/15/08 07:28 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Excellent example of the blackout being shot straight in. Notice no overspray on the bottom of the upper rail which would be there if it was shot upward.
Re: 1968 Road Runner undercarriage color [Re: beepbeep] #73563
06/15/08 09:28 PM
06/15/08 09:28 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That red '69 RR looks like it was sprayed pretty much downward, looking at the flanged openings; the cars I've gone by appeared to be shot upward, with black on the bottom yoke and the underside of the flange, but none on the top of the flange. Maybe more variation than I was aware of?
My dark blue '63 had no blackout, but my '64 did. Can't recall my old dark blue '68, but my dark green '69 had blackout, as did my red '68, and the lighter-color (white, lighter greens, & turquoise '68s - '70s I've owned.
Re: 1968 Road Runner undercarriage color [Re: topside] #73564
06/16/08 04:30 AM
06/16/08 04:30 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
All you need to do is look at the picture posted above of the Coronet on the production line, black all over the left side of the upper flange.
Also look at the left fender, polishing compound runs on the inner fender.
Re: 1968 Road Runner undercarriage color [Re: beepbeep] #73565
06/16/08 08:43 AM
06/16/08 08:43 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Dave..
I'm painting my '68 Hemi Charger R/T with the dark dip primer paint supplied to me from Dave over at Performance Car Graphics.. Then applying the color with the overspray factory OEM method.... If you haven't painted your car undercarriage yet, then mine would probably be a good example..
Troy
Houston Mopar Connection Club
Re: 1968 Road Runner undercarriage color [Re: hemi68charger] #73566
06/16/08 09:27 AM
06/16/08 09:27 AM
DFW
DFW
Troy, nope, not in paint yet. I should be wrapping up the welding in the next few months. My plan is August for everything that needs to be welded to be done. So probably September or October I'll be doing the spraying. Thanks for the tips and yeah, we'll have to get together at some point!!!
Cheers
Re: 1968 Road Runner undercarriage color [Re: 68RRFlyer] #73567
06/16/08 12:07 PM
06/16/08 12:07 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
Let me add a little more confusion about how the grill blackout was painted:
In the first two pictues of my un-molested 69 RR I posted, you could clearly see the paint on "right" side was thicker and cover a much larger area than the paint on the "left" side.
If you look at this pictue, of the "left" side directly behind the opening for the headlight and the turn signel light wiring. It appears that it was painted through the openings.
So with these variations on just one car it is understandable that there would be variations between cars and plants.
Re: 1968 Road Runner undercarriage color [Re: 474218] #73568
06/16/08 12:30 PM
06/16/08 12:30 PM
cataclysm80 Offline
cataclysm80  Offline
Tav
Re: 1968 Road Runner undercarriage color [Re: cataclysm80] #73569
06/16/08 12:56 PM
06/16/08 12:56 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Dave,
This is how we did my 68 Road Runner. The idea was pretty much follow the factory "flavor" of overspray and primer look on the underside. Probably leaning more to over-restored but not wanting the body color 100%
You can also check out the rest of the pictures from the Clark Classic Restoration website.
http://www.clarkclassic.com/mygallery/index.asp?CatID=31&offset=0
68 Hemi Road Runner
Re: 1968 Road Runner undercarriage color [Re: 68jim] #73570
06/16/08 12:57 PM
06/16/08 12:57 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Picture #2
Re: 1968 Road Runner undercarriage color [Re: 68jim] #73571
06/16/08 01:12 PM
06/16/08 01:12 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I agree with the other posts about the blackout probably being somewhat different from car to car but basically the same. It all depends how you personally want it to look. I took plenty of pictures as I was taking my car apart and it was pretty evident that whoever painted my blackout shot it differently from the left side to the right side...maybe the dude was a southpaw... In the end I choose to tape it off cleanly and shoot it all black. I'm sure it took me longer to paint than the dude on the assembly line but I did not miss big areas either.
Good luck on your decision.
68 Hemi Road Runner
Re: 1968 Road Runner undercarriage color [Re: 474218] #73572
06/16/08 01:42 PM
06/16/08 01:42 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
The point that is overlooked here is that the over spray was not the focal point with the employees at the factory. The factory engineered drawings spelled out how far the over spray could cover but the objective was to remove the reflective paint characteristics behind the grill. If you spray the black to try and emulate the over spray, chances are that the primary purpose of painting the cowl area will not appear as it should. Simply cover the desired area and let the chips fall where they may. The over spray pattern will probably be very similar to the way it was when originally applied. Also remember that there could be up to six different colors showing on the underside of a vehicle. Depending on the color of the car you could have a light gray phosphate coating, followed by the tank dip primer, followed by red oxide primer, followed by light gray primer, followed by the body color and then the pinch weld blackout.
Re: 1968 Road Runner undercarriage color [Re: ECS] #73573
06/16/08 01:54 PM
06/16/08 01:54 PM
DFW
DFW
Thanks gang!
Jim, your pics and the link will help me out immensely as I get to that stage. Thanks so much for the photos. I'll probably do a blackout similar to yours and defenitely leave the primer underneath. Thanks for all the tips.
Cheers
Re: 1968 Road Runner undercarriage color [Re: 68RRFlyer] #73574
06/20/08 09:36 PM
06/20/08 09:36 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Moparabe, Here ya go, hope it helps also look a the thread for the AAR undercarriage.
Careful, your character's showing!
Re: 1968 Road Runner undercarriage color [Re: 68jim] #73575
06/21/08 10:02 AM
06/21/08 10:02 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Dave,
68 Hemi Road Runner
My org. 68 has a lot more covered than that, but we know that it wasn't the same guy spraying them all! My floor boards are about covered but the tunnel isn't
As far as the blackout is it true the darker the car the less black out? My car is more like pavell's while my old 69 T-5 Dodge was srayed much heavier
