brake bleeding problem #735555
06/28/10 10:44 AM
06/28/10 10:44 AM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
haveing a heck of a time bleeding my brakes, everything in the system is new. First of no leaks. I bleed them using the standard procedure, RR first then LR,RF and LF. still the pedal bleeds off when i press it. first response will ask if I brench bleed the MC, i did. could i have a bad MC? any ideas how?
Re: brake bleeding problem [Re: AK_JH27] #735556
06/28/10 10:53 AM
06/28/10 10:53 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
If it loses pressure(falls off) without leaking,it sure sounds like a bad master cylinder.I have seen new rebuilt units be bad out of the box before.
Re: brake bleeding problem [Re: Dunnuck Racing] #735557
06/28/10 11:41 AM
06/28/10 11:41 AM
searcy ark
W
waspnest69 Offline
waspnest69  Offline
W
searcy ark
Check your bolt to pedal make sure its tight...I had same problem turned out the bolt was loose and not allowing correct rod to mc travel.
Re: brake bleeding problem [Re: waspnest69] #735558
06/28/10 03:13 PM
06/28/10 03:13 PM
scratchnfotraction Offline
check to make sure the MC is not leaking to the inside of the firewall when you check the bolt/rod also
Re: brake bleeding problem [Re: scratchnfotraction] #735559
06/28/10 03:38 PM
06/28/10 03:38 PM
Buy 2 Edelman brand brass male inverted flare plugs for several $$ at your parts house and cap the M/C and if it is good (& bled out) the pedal will be rock hard w virtually no travel
Re: brake bleeding problem [Re: RapidRobert] #735560
06/28/10 09:25 PM
06/28/10 09:25 PM
Indiana
F6F6Dodge Offline
F6F6Dodge  Offline
Indiana
disc or drums???
Re: brake bleeding problem [Re: RapidRobert] #735561
06/28/10 11:44 PM
06/28/10 11:44 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
ok- worked all day on this problem and here's where am at.
I plugged the MC and pedal is hard it doesnt bleed off, MC is good then I connected the rear lines and left the front plugged, pedal is hard still. looks like the fronts are the problem. to double check ;again plugged the rears on the MC and connected the fronts only and pedal bleed to the floor. confirmed there must be air getting in somewhere in the front circut. So i went and double checked all connections again and no leaks.
I was told to make sure the bleeder screws are above the brake line, would this make a difference? I am at a dead end here, any body wanna offer more suggustions?
Re: brake bleeding problem [Re: AK_JH27] #735562
06/29/10 01:23 AM
06/29/10 01:23 AM
I was told to make sure the bleeder screws are above the brake line, would this make a difference? any body wanna offer more suggustions?
Progress! yes the bleeder screws need to be generally toward the top, not neccessarily @12 O'clock but where the bleeder passage meets the bore that needs to be @12 O'clock as you know air will rise to the top of the bore and the factory location is generally adequate. Might have a helper push/relaease the pedal several times real fast then hold it down to agitate the fluid/air mix as you IMMEDIATELY open the bleeder to help clear the air out of there and be sure to close the bleeder before he lets the pedal up so air dont get by the bleeder threads and I like to have a block of wood under the pedal so it (the M/C cups) doesn't go past it's normal smooth travel area. Good luck and holler back.
Re: brake bleeding problem [Re: RapidRobert] #735563
06/29/10 11:40 AM
06/29/10 11:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes the bleeders have to be facing up or you will never get a pedal.Dont ask how I know and Ive been doing it for 40 years.That and what master are you using?It has to be a disc drum master if thats what you are running.Frt drum master dosent push enough fluid.Rocky
Chrysler Firepower
