Cam specs #735232
06/27/10 11:05 PM
06/27/10 11:05 PM
Sioux Falls,South Dakota
fouronthefloor77 Offline OP
I recently tore down the 440 in my challenger.
The cam that was installed in it was a single bolt crane. the markings on the end are SSH-330-NC. What are the specs on this cam?
Re: Cam specs [Re: fouronthefloor77] #735233
06/28/10 05:04 AM
06/28/10 05:04 AM
NL
Frederick Offline
Frederick  Offline
NL
The SSH part sounds more like a Racer Brown cam to me?
But I don't see the 330 in the list:
http://www.4secondsflat.com/RB%20Cam%20Specs.htm
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: Cam specs [Re: Frederick] #735234
06/28/10 04:42 PM
06/28/10 04:42 PM
It says Crane on the snout of the cam. This engine was put together in the late 70's could it be a discontinued part#? maybe a custom grind? When it ran it had a definite lope and pulled about 8inches at idle so it's not a stock replacement.
