Page 1 of 4 1 2 3 4
What "degree" Thermostat #735088
06/27/10 09:16 PM
06/27/10 09:16 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
are some of you running in this summer heat?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What "degree" Thermostat [Re: joedust451] #735089
06/27/10 09:19 PM
06/27/10 09:19 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I run 180* stats all year long here in Phoenix
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: What "degree" Thermostat [Re: joedust451] #735090
06/27/10 09:19 PM
06/27/10 09:19 PM
Maryville tn
67coronetman Offline
Maryville tn
I have used 160 & 180 it still get up there will be putting a fan shroud on tomorrow.!
Old car are me......
Re: What "degree" Thermostat [Re: joedust451] #735091
06/27/10 09:20 PM
06/27/10 09:20 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
180 Napa Superstat. Year round.
Re: What "degree" Thermostat [Re: DennisH ] #735092
06/27/10 09:43 PM
06/27/10 09:43 PM
IN
ahy Offline
ahy  Offline
IN
180 year around. I like to see mine run 180 - 195.
Re: What "degree" Thermostat [Re: ahy] #735093
06/27/10 09:50 PM
06/27/10 09:50 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
NAPA 195 (+ Royal Purple Ice)and it never moves once it is up to temp while driving.
Re: What "degree" Thermostat [Re: YO7_A66] #735094
06/27/10 10:15 PM
06/27/10 10:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
195 in the Texas 100*+ weather and it never hits 200 even in stop and go traffic. 408 stroker.
383man [Re: stumpy] #735095
06/27/10 11:16 PM
06/27/10 11:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
160 in my 63 and the boys Dart. Cars run about 180 on the hottest days. Ron
Re: 383man [Re: 383man] #735096
06/27/10 11:51 PM
06/27/10 11:51 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I use a 160, motor never goes over 180 and it gets kind of warm some times here in Arizona.
Re: 383man [Re: Darryls-Demon] #735097
06/28/10 01:41 AM
06/28/10 01:41 AM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
160
Re: What "degree" Thermostat [Re: joedust451] #735098
06/28/10 04:36 AM
06/28/10 04:36 AM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
Don't be confused. Thermostats are essentially used to keep an engine hot, not to keep it cold. Kim
Re: What "degree" Thermostat [Re: last426] #735099
06/28/10 11:51 AM
06/28/10 11:51 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Engines are more efficent and have less wear if run at 185-195. Any lower and your not getting all it's got and are wearing parts faster.
Re: What "degree" Thermostat [Re: stumpy] #735100
06/28/10 12:04 PM
06/28/10 12:04 PM
P
Paul_Fancsali Offline
P
195 even in summer and 180 in 11.0 engine. Car runs better and stronger with higher temp
Re: What "degree" Thermostat [Re: stumpy] #735101
06/28/10 12:53 PM
06/28/10 12:53 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
I'd say your right, i've notice it runs stronger at 185 then 150-160*, i'm going back to the 180*
Re: What "degree" Thermostat [Re: stumpy] #735102
06/28/10 01:00 PM
06/28/10 01:00 PM
hooziewhatsit Offline
Also, if your cooling system is good enough, you should never go much higher than your thermostat rating, even on the hottest day in summer.
A lower temp thermostat is just a bandaid for overheating.
Re: What "degree" Thermostat [Re: stumpy] #735103
06/28/10 01:03 PM
06/28/10 01:03 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I disagree...195 is getting close to max on a stock heat gauge. I run a 160 in My stroker and it runs around 180 on hot days. I will add that in My opinion, an engine is not gonna run fast at 150 to 160 but heat is an enemy. I've gotten far more miles out of a "cool" running motor than one that runs hot. If You're a part time "dragger" , fashion some cardboard over the rad to get the temp up if that's what you want. Thermostats were designed to get a car up to NORMAL operating temp quicker than no stat. This also gets heat to the heater core faster when the stat opens. I run two gauges for temp...stock in dash and a good aftermarket. They run about the same for temp readings. 195 is close to overheating or being out of normal operating range, on a stock in dash gauge. 180 is about mid range and that's where I like it. But...to each their own...My opinion
Re: What "degree" Thermostat [Re: terzmo] #735104
06/28/10 01:08 PM
06/28/10 01:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The factories have dumped billions of dollars into engine research. Modern cars run around 200 degrees. They are more efficient and pollute less at those temps.
They put much more time and money into it that I ever will by second guessing them while standing in my driveway.
I'll defer to the engineers.
- Stu Harmon
Re: What "degree" Thermostat [Re: hooziewhatsit] #735105
06/28/10 01:11 PM
06/28/10 01:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
A stat, on less faulty, will not cause a engine to over heat. A stat CANNOT control temperatures above the stat rating. If your engine is over heating a colder stat will just make it take longer to reach that temp.
Re: What "degree" Thermostat [Re: MoparforLife] #735106
06/28/10 01:14 PM
06/28/10 01:14 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
195
Re: What "degree" Thermostat [Re: feets] #735107
06/28/10 01:17 PM
06/28/10 01:17 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
YES...new cars run hotter. My silverado runs at a constant 210...it's designed that way. 60's cars were designed to run at lower temps. There were no smog pumps, or other rubbish back then. The engineers designed them, that way...back then..like comparing apples to oranges
Page 1 of 4 1 2 3 4
