Good Mopar Mechanic in Houston #73502
06/14/08 01:28 PM
06/14/08 01:28 PM
Texas
RaiderLefty Offline OP
Texas
Does anyone know of a good Mopar mechanic in the Houston TX area? I'm specifically looking for someone to help me time the car ('69 RR w/ 440/6) and adjust the 6-bbl setup.
I want to do the work myself but I cannot get the car to idle in order to check the timing and I'm afraid I'm going to do more harm then good trying to adjust things myself (I'm a newb).
I tried adjusting the idle screw on the primary carb this morning but it didn't do much good....car still wouldn't idle.
Suggestions?
Re: Good Mopar Mechanic in Houston [Re: RaiderLefty] #73503
06/16/08 08:48 AM
06/16/08 08:48 AM
Texas
Texas
Nobody knows someone that could help me out in Houston?
I spent some time again yesterday adjusting the idle so that I could get the engine timed properly. Unfortunately the engine would either idle too low (~700rpm) and die quickly or it would idle too high (~1300rpm).
When I took it out for a drive it runs decently but under WOT there is a momentary bog as the secondaries come in.
I want/need to learn how to fix this but don't really know where to start.
